Datasheet Texas Instruments PCM5242RHBR — Даташит
Серия | PCM5242 |
Модель | PCM5242RHBR |
4,2-VRMS DirectPath™, 32 бита, 384 кГц, 114 дБ Аудио Стерео ЦАП 32-VQFN от -25 до 85
PCM5242 4.2-VRMS DirectPath, 114-dB Audio Stereo Differential-Output DAC with 32-bit, 384-kHz PCM Interface datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 15 окт 2014
![]() 32 предложений от 13 поставщиков Микросхема Преобразователь DA, 4.2VRMS DirectPathTM, 114dB Audio Stereo Differential-Output DAC with 32Bit, 384kHz PCM Interface 32-VQFN -25 to 85 | |||
PCM5242RHBR Texas Instruments | 167 ₽ | ||
PCM5242RHBR Texas Instruments | от 169 ₽ | ||
PCM5242RHBR Texas Instruments | от 464 ₽ | ||
PCM5242RHBR Texas Instruments | 1 459 ₽ |
Pin | 32 |
Package Type | RHB |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | PCM5242 |
Width (мм) | 5 |
Length (мм) | 5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Analog Outputs | 2 |
Архитектура | Delta Sigma with line driver |
Control Interface | I2C,SPI,H/W |
DAC Channels | 2 |
DAC SNR(Typ) | 114 дБ |
Package Size: mm2:W x L | 32VQFN: 25 mm2: 5 x 5(VQFN) PKG |
Разрешение | 32 Bits |
Sampling Rate(Max) | 384 kHz |
- Evaluation Modules & Boards: PCM5242RHBEVM
PCM5242RHBEVM: 4.2-VRMS DirectPathВ™, 114-dB Audio Stereo Differential-Output DAC Eval Board
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5242 (2)
- PCM5242RHBR PCM5242RHBT
- Semiconductors > Audio > Audio Converters > Audio DAC
