Datasheet Texas Instruments PCM5141PW — Даташит
СерияPCM5141
МодельPCM5141PW
2 В RMS DIRECTPATH 106 дБ Аудио Стерео ЦАП с интерфейсом PCM и полностью программируемым miniDSP 28-TSSOP от -25 до 85
PCM514x 2-VRMS DirectPathв„ў, 112/106-dB Audio Stereo DAC With 32-bit, 384-kHz PCM Interface datasheet
PDF, 2.4 Мб, Версия: B, Файл опубликован: 13 янв 2016
Микросхема Преобразователь DA, 2VRMS DirectPathTM, 112/106dB Audio Stereo DAC with 32Bit, 384kHz PCM Interface
PCM5141PW
191 ₽
727GS
PCM5141PW
от 302 ₽
IC Home
PCM5141PW
365 ₽
PCM5141PW
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаPCM5141
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураDelta Sigma with line driver
Control InterfaceI2C,SPI,H/W
DAC Channels2
DAC SNR(Typ)106 дБ
Package Size: mm2:W x L28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) PKG
Разрешение32 Bits
Sampling Rate(Max)384 kHz
  • Evaluation Modules & Boards: PCM5142EVM-U
    PCM5142 Evaluation Module
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5141 (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM5141PW
