Datasheet Texas Instruments PCM5102A-Q1 — Даташит
Серия | PCM5102A-Q1 |
Automotive Catalog 2VRMS DirectPathв„ў, 112dB Audio Stereo DAC with 32-bit, 384kHz PCM Interface
PCM510xA 2.1 VRMS, 112/106/100 dB Audio Stereo DAC with PLL and 32-bit, 384 kHz PCM Interface datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 6 май 2015
![]() PCM 5102A audio DAC stereo - ЦАП 24 бит 192кГц - модуль высококачественного звукового ЦАП на микросхеме PCM5102 предназначен для использования... | |||
PCM5102A аудио ЦАП 24 бит 192кГц stereo | 450 ₽ | ||
MDL-PCM5102A-AudioDAC | 892 ₽ |
PCM5102AQPWRQ1 | |
Статус продукта | В производстве |
PCM5102AQPWRQ1 | |
N | 1 |
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | P5102AQ1 |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Parameters / Models | PCM5102AQPWRQ1![]() |
Analog Outputs | 2 |
Архитектура | Delta Sigma with line driver |
Control Interface | H/W |
DAC Channels | 2 |
DAC SNR(Typ), дБ | 112 |
Package Size: mm2:W x L, PKG | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) |
Разрешение, Bits | 32 |
Sampling Rate(Max), kHz | 384 |
PCM5102AQPWRQ1 | |
- A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging FiltersPDF, 62 Кб, Файл опубликован: 27 сен 2000
In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively. - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM5102A-Q1 (1)
- Semiconductors> Audio> Audio Converters> Audio DAC
