Datasheet Texas Instruments PCM3002EG/2K — Даташит
Серия | PCM3002 |
Модель | PCM3002EG/2K |
Маломощный стереокодек с линейным выходом (программное управление) 24-SSOP
16-/20-Bit Single-Ended Analog Input/Output SoundPlus? Stereo Audio CODECs datasheet
PDF, 686 Кб, Версия: A, Файл опубликован: 28 окт 2004
Купить PCM3002EG/2K на РадиоЛоцман.Цены — от 109 до 847 ₽ 15 предложений от 12 поставщиков Audio Codec 2ADC / 2DAC 20Bit 24Pin SSOP T/R | |||
PCM3002EG/2K Texas Instruments | от 109 ₽ | ||
PCM3002EG/2K Texas Instruments | 352 ₽ | ||
PCM3002EG/2K Texas Instruments | 577 ₽ | ||
PCM3002EG/2K Texas Instruments | 847 ₽ |
Pin | 24 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Width (мм) | 5.3 |
Length (мм) | 8.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
ADC Channels | 2 |
ADC SNR(Typ) | 90 дБ |
Analog Inputs | 2 |
Analog Outputs | 2 |
DAC Channels | 2 |
DAC SNR(Typ) | 94 дБ |
Digital Audio Interface | R,L,I2S |
Package Size: mm2:W x L | 24SSOP: 64 mm2: 7.8 x 8.2(SSOP) PKG |
Sampling Rate(Max) | 48 kHz |
Бессвинцовая технология (Pb Free) | Да |
- Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP PortPDF, 105 Кб, Файл опубликован: 8 июл 2009
This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications - Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
- Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio - Dyamic Performance Testing of Digital Audio D/A ConvertersPDF, 145 Кб, Файл опубликован: 2 окт 2000
This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture. - Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock - A DSP/BIOS PCM3002 Codec Device Driver for the TMS320C5416 (Rev. A)PDF, 87 Кб, Версия: A, Файл опубликован: 30 июн 2003
- A DSP/BIOS PCM3002 codec Device Driver for the TMS320C6416 TEB (Rev. A)PDF, 74 Кб, Версия: A, Файл опубликован: 1 июн 2003
- Out-of-Band Noise Measurement Issues for Audio CodecsPDF, 145 Кб, Файл опубликован: 6 дек 2006
Серия: PCM3002 (6)
- PCM3002E PCM3002E/2K PCM3002E/2KG4 PCM3002EG PCM3002EG/2K PCM3002EG4
- Semiconductors > Audio > Audio Converters > Audio CODEC
