Datasheet Texas Instruments PCM1796DBG4 — Даташит
СерияPCM1796
МодельPCM1796DBG4
Стерео ЦАП 123 дБ (S/W Control) 28-SSOP от -25 до 85
24-Bit 192-kHz Sampling Advanced-Segment Audio Stereo DAC datasheet
PDF, 689 Кб, Версия: A, Файл опубликован: 30 ноя 2006
DAC 2CH Segment 24Bit 28Pin SSOP Tube
PCM1796DBG4
305 ₽
T-electron
PCM1796DBG4
421 ₽
PCM1796DBG4
850 ₽
Akcel
PCM1796DBG4
Вебинар «Как выбрать идеальный силовой модуль: решения SUNCO для силовой электроники» (03.12.2024)
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY47
МаркировкаPCM1796
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
Analog Outputs2
АрхитектураAdvanced Segment
Control InterfaceSPI,I2C
DAC Channels2
DAC SNR(Typ)123 дБ
Package Size: mm2:W x L28SSOP: 80 mm2: 7.8 x 10.2(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1796 (3)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1796DBG4
