Популярные микроконтроллеры Nuvoton серий М2354 и М251 со склада компании Смарт-ЭК
Datasheet Texas Instruments PCM1789PWRG4 — Даташит
СерияPCM1789
МодельPCM1789PWRG4
Стерео ЦАП 113 дБ SNR 24-TSSOP от -40 до 85
PCM1789 24-Bit, 192-kHz Sampling, Enhanced Multi-Level О”ОЈ, Stereo, Audio Digital-to-Analog Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 31 авг 2015
Микросхема Преобразователь DA, DAC 2CH Delta-Sigma 24Bit 24Pin TSSOP T/R
PCM1789PWRG4
104 ₽
PCM1789PWRG4
125 ₽
T-electron
PCM1789PWRG4
171 ₽
IC Home
PCM1789PWRG4
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаPCM1789
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Analog Outputs2
АрхитектураCurrent Segment DAC
Control InterfaceSPI,I2C,H/W
DAC Channels2
DAC SNR(Typ)113 дБ
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1789 (4)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1789PWRG4
