Datasheet Texas Instruments PCM1690-Q1 — Даташит
СерияPCM1690-Q1
Автомобильный каталог, 8-канальный аудио ЦАП с соотношением сигнал/шум 113 дБ и дифференциальными выходами
24-Bit, 192-kHz Sampling, Enhanced Multi-Level О”ОЈ,Eight-Channel Audio Digital.. datasheet
PDF, 1.4 Мб, Файл опубликован: 21 июн 2011
62 предложений от 26 поставщиков
Интегральные микросхемы Микросхемы сбора данных - АЦП/ЦАП специального назначения
PCM1690DCAR
178 ₽
T-electron
PCM1690DCAR
243 ₽
PCM1690DCAR
от 308 ₽
PCM1690IDCARQ1
PCM1690IDCARQ1
Статус продуктаВ производстве
PCM1690IDCARQ1
N1
Pin48
Package TypeDCA
Industry STD TermHTSSOP
Package QTY2000
МаркировкаPCM1690Q
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Parameters / ModelsPCM1690IDCARQ1
PCM1690IDCARQ1
Analog Outputs8
АрхитектураCurrent Segment
Control InterfaceSPI,I2C,H/W
DAC Channels8
DAC SNR(Typ), дБ113
Package Size: mm2:W x L, PKG48HTSSOP: 101 mm2: 8.1 x 12.5(HTSSOP)
Разрешение, Bits24
Sampling Rate(Max), kHz192
PCM1690IDCARQ1
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1690-Q1 (1)
  • Semiconductors> Audio> Audio Converters> Audio DAC
На английском языке: Datasheet Texas Instruments PCM1690-Q1
Публикации по теме
