Datasheet Texas Instruments PCM1680DBQG4 — Даташит
СерияPCM1680
МодельPCM1680DBQG4
8-канальный аудио ЦАП 105 дБ SNR 28-SSOP от -25 до 70
24-Bit, 192-kHz Sampling, Enhanced Multilevel, Delta-Sigma, Audio D/A Converter datasheet
PDF, 793 Кб, Версия: B, Файл опубликован: 23 окт 2008
16 предложений от 12 поставщиков
TEXAS INSTRUMENTS PCM1680DBQG4 Digital to Analogue Converter, 24Bit, 192KSPS, Serial, 4.75V to 5.25V, SSOP, 28Pins
PCM1680DBQG4
167 ₽
T-electron
PCM1680DBQG4
278 ₽
PCM1680DBQG4
395 ₽
ЗУМ-СМД
PCM1680DBQG4
Pin28
Package TypeDBQ
Industry STD TermSSOP
Package QTY40
МаркировкаPCM1680
Width (мм)3.9
Length (мм)9.9
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Analog Outputs8
АрхитектураDelta-Sigma
Control InterfaceSPI,I2C
DAC Channels8
DAC SNR(Typ)105 дБ
Package Size: mm2:W x L28SSOP: 59 mm2: 6 x 9.9(SSOP) PKG
Разрешение24 Bits
Sampling Rate(Max)192 kHz
  • THD+N Versus Frequency Characteristics and Spectra of the PCM1717/18/19/20/23/27
    PDF, 107 Кб, Файл опубликован: 27 сен 2000
    The following application bulletin describes the theory and actual performance of THD+N versus frequency characteristics for the PCM1717 series which include on-chip digital filters. The contents of this article apply to the PCM1717 and other devices which use the same digital filter architecture and delta-sigma DAC, such as PCM1718, PCM1719, PCM1720, PCM1723, and PCM1727.
  • A Low Noise, Low Distortion Design for Antialiasing and Anti-Imaging Filters
    PDF, 62 Кб, Файл опубликован: 27 сен 2000
    In any digitizing system, antialiasing and anti-imaging filters are used to prevent the signal frequencies from folding back around the sample frequency and causing false (or alias) signals from appearing in the signal we are attempting to digitize. Very often, these filters must be very complex, high order analog filters in order to do their job effectively.
  • Dyamic Performance Testing of Digital Audio D/A Converters
    PDF, 145 Кб, Файл опубликован: 2 окт 2000
    This application bulletin will provide the reader with an understanding of test methods for audio digital-to-analog converters (DACs). In particular, delta-sigma DACs require a special understanding due to the nature of their architecture.
Серия: PCM1680 (3)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments PCM1680DBQG4
