Datasheet Texas Instruments OMAP3530ECUS — Даташит
Серия | OMAP3530 |
Модель | OMAP3530ECUS |
Прикладной процессор 423-FCBGA от 0 до 90
![]() 37 предложений от 19 поставщиков Интегральные микросхемы Встроенные микросхемы - Микропроцессоры | |||
OMAP3530ECUS Texas Instruments | от 264 ₽ | ||
OMAP3530ECUS Texas Instruments | 482 ₽ | ||
OMAP3530ECUS Texas Instruments | по запросу | ||
Pin | 423 |
Package Type | CUS |
Industry STD Term | FC/CSP |
JEDEC Code | S-PBGA-N |
Package QTY | 90 |
Carrier | JEDEC TRAY (5+1) |
Маркировка | 3530ECUS |
Width (мм) | 16 |
Length (мм) | 16 |
Thickness (мм) | .96 |
Pitch (мм) | .65 |
Max Height (мм) | 1.4 |
Mechanical Data | Скачать |
2D & 3D Graphics | Hardware Accelerated |
ARM CPU | 1 ARM Cortex-A8 |
ARM MHz | 720 Max. |
Integrated TI C64x DSP | Up to 520 MHz |
Memory Interface | 1 16-bit LPDDR , 1 32-bit SDRC Dual Channel |
Performance | D1 |
Process Node | 65nm |
- Evaluation Modules & Boards: TMDSEVM3530
OMAP35x Evaluation Module (EVM)
- OMAP3530 Power Consumption SummaryPDF, 19 Кб, Файл опубликован: 8 янв 2010
This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at: http://wiki.davincidsp.com/index.php/OMAP3530_Power_Estimation_Spreadsheet.Power consumption on the OMAP3530 device is highly application-dependent therefore a sp
- OMAP3530 Easy CUS Package PCB Escape Routing (Rev. A)PDF, 2.6 Мб, Версия: A, Файл опубликован: 25 мар 2010
The OMAP3530 CUS package is designed with a new technology called Via Channel™ array. This technology allows for easy routing of the device in two signal and two power layers using standard 20 mil diameter and 10 mil finished hole size via; it is cost and time effective. This application report shows how to easily route the entire package by first routing one quadrant only and then copying i - Ultrasound Scan Conversion on TI's C64x+ DSPsPDF, 656 Кб, Файл опубликован: 3 апр 2009
One of the recent significant developments in ultrasound is the emergence of portable and handheld ultrasound machines and their rapid acceptance in the market place.Because of their power efficiency and high performance digital signal processor (DSP) based devices have been increasingly used as the main processing engine in these portable and hand carried units.This application report dis
- OMAP35x Linux PSP Data SheetPDF, 1.6 Мб, Файл опубликован: 16 окт 2009
- OMAP3530/25/15/03 CBB CBC & CUS Reflow ProfilesPDF, 27 Кб, Файл опубликован: 13 ноя 2009
This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at:http://wiki.davincidsp.com/index.php/OMAP3_CBB_CBC_CUS_Reflow_Profiles
Reflow profiles are dependent on numerous factors including package type number of components bo
- OMAP35x 0.65mm Pitch Layout Methods (Rev. B)PDF, 372 Кб, Версия: B, Файл опубликован: 26 июн 2008
It is easy to see from the unique look that the OMAP35x parts have a very unusual footprint. The OMAP35x ball grid array is designed with new technology called the Via Channel array which makes significant printed circuit board (PCB) cost savings possible. If the PCB is routed correctly this cost savings can be substantial. This application report explains how this is possible and shows several - Powering OMAP3 With TPS65023: Design-In Guide (Rev. B)PDF, 181 Кб, Версия: B, Файл опубликован: 2 мар 2009
- OMAP35x to AM35x Hardware Migration GuidePDF, 19 Кб, Файл опубликован: 24 май 2010
This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at:http://processors.wiki.ti.com/index.php/OMAP35x_to_AM35x_Hardware_Migration_Guide.
This article describes hardware device considerations to migrate a design
- OMAP35x to AM37x Hardware Migration GuidePDF, 37 Кб, Файл опубликован: 3 июн 2010
This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute visit this topic at:http://processors.wiki.ti.com/index.php/OMAP35x_To_AM37x_Hardware_Migration_Guide.
The OMAP35x to AM37x Hardware Migration Guide describes device consideratio
- PCB Design Guidelines for 0.4mm Package-On-Package (PoP) Packages Part I (Rev. B)PDF, 6.7 Мб, Версия: B, Файл опубликован: 13 июн 2009
Ball grid array (BGA) packages having 0.4mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies; the standard rules of thumb don't apply anymore. In fact the design guidelines for 0.4mm and 0.5mm differ primarily due to issues surrounding shorts or opens between balls under the processor.In addition to the de - PCB Assembly Guidelines for 0.4mm Package-On-Package (PoP) Packages Part II (Rev. A)PDF, 2.4 Мб, Версия: A, Файл опубликован: 1 ноя 2013
Once the bottom circuit board has been designed the assembly guidelines for package-on-package (PoP) versions of the OMAP35xx processor and the memory device must be considered.PoP packages have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of final assembly: the circuit board design the solder paste char
- PCB Assembly Guidelines for 0.5mm Package-on-Package Apps Processors Part IIPDF, 1.2 Мб, Файл опубликован: 23 июн 2010
Once the main printed circuit board (PCB) has been designed the assembly guidelines for the 0.5mm package-on-package (PoP) applications processor and companion memory device must be considered. PoP applications processors have an enormous number of variables associated with assembly. The following factors have a major effect on the quality and reliability of PCB assembly: PoP applications process - PCB Design Guidelines for 0.5mm Package-On-Package Apps Processors Part IPDF, 2.0 Мб, Файл опубликован: 23 июн 2010
Ball grid array (BGA) packages having 0.5mm ball pitch require careful attention to printed circuit board (PCB) design parameters to successfully yield reliable and robust assemblies. PCBs with package-on-package (PoP) technology have additional assembly requirements and options that need to be considered when designing the PCB.Fine-pitch PCB design is a team effort and may require more than
- Running a TMS320C64x+ Codec Across TMS320C64x+ Based DSP PlatformsPDF, 969 Кб, Файл опубликован: 24 сен 2009
This application report describes the device differences to be taken care for running the C64x+™ video codec software on different C64x+ based platforms. This document assumes that the codec software is developed for the C64x+ digital signal processor (DSP) core. As many TI platforms have a C64x+ DSP this document gives the details for running the standalone codec software on a C64x+ platfo - Introduction to TMS320C6000 DSP OptimizationPDF, 535 Кб, Файл опубликован: 6 окт 2011
- 3530ECBCAMERCURY 3530ECUSAGRM OMAP3530DCBB OMAP3530DCBB72 OMAP3530DCBBA OMAP3530DCBC OMAP3530DCBC72 OMAP3530DCBCA OMAP3530DCUS OMAP3530DCUS72 OMAP3530DCUSA OMAP3530ECBB OMAP3530ECBB72 OMAP3530ECBBA OMAP3530ECBBALPD OMAP3530ECBBAR OMAP3530ECBBLPD OMAP3530ECBC OMAP3530ECBC72 OMAP3530ECBCA OMAP3530ECUS OMAP3530ECUS72 OMAP3530ECUSA
- Semiconductors > OMAP™ Applications Processors > OMAP™ Processors > OMAP™ 3 Processors
