Datasheet Texas Instruments LMP91200MTX/NOPB — Даташит
СерияLMP91200
МодельLMP91200MTX/NOPB
Встроенный AFE для маломощных приложений измерения pH 16-TSSOP от -40 до 125
LMP91200 Configurable AFE for Low Power Chemical Sensing Apps datasheet
PDF, 981 Кб, Версия: E, Файл опубликован: 29 фев 2016
Integrated AFE for Low-Power pH Sensing Applications 16-TSSOP -40℃ to 125℃
LMP91200MTX/NOPB
277 ₽
T-electron
LMP91200MTX/NOPB
308 ₽
LMP91200MTX/NOPB
331 ₽
LMP91200MTX/NOPB
Pin1616
Package TypePWPW
Industry STD TermTSSOPTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка00MTLMP912
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)1.8 В
ApplicationspH sensing
Integrated FeaturesCurrent Sources (iDACs),PGA
InterfaceSerial SPI
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Ток потребления0.05 мА
  • Evaluation Modules & Boards: SPIO-4
    Sensor AFE Digital Controller Board
  • Evaluation Modules & Boards: LMP91200EVAL
    Sensor AFE Evaluation Board for pH sensors
  • AN-2254 MSP430 Interface to LMP91200 Code Library (Rev. A)
    PDF, 6.6 Мб, Версия: A, Файл опубликован: 1 май 2013
    The MSP430в„ў is an ideal microcontroller solution for low-cost, low-power precision sensor applicationsbecause it consumes very little power. The LMP91200 is a configurable sensor analog front end (AFE) foruse in low power analytical sensing applications. This library provides functions to facilitate the interfacingof any MSP430 device to a LMP91200. Any device within the MSP430 family
Серия: LMP91200 (2)
  • Semiconductors > Sensing Products > Gas/Chemical Sensing AFEs
На английском языке: Datasheet Texas Instruments LMP91200MTX/NOPB
