Datasheet Texas Instruments LMK01000ISQ/NOPB — Даташит
СерияLMK01000
МодельLMK01000ISQ/NOPB
Высокопроизводительный буфер, делитель и распределитель тактовой частоты 1,6 ГГц 48-WQFN от -40 до 85
Fam LMK01000 Fam 1.6GHz HPer Clk Buffer, Divider and Distributor datasheet
PDF, 832 Кб, Версия: G, Файл опубликован: 15 окт 2009
IC CLK BUFFER 2:8 1.6GHZ 48WQFN / Clock Fanout Buffer (Distribution), Divider IC 2:8 1.6 GHz 48-WFQFN Exposed Pad
LIXINC Electronics
LMK01000ISQ/NOPB
80 ₽
LMK01000ISQ/NOPB
636 ₽
LMK01000ISQ/NOPB
HXD Co.
LMK01000ISQ/NOPB
Pin48
Package TypeRHS
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY1000
МаркировкаK01000 I
Width (мм)7
Length (мм)7
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Additive RMS Jitter(Typ)30 fs
Input Frequency(Max)1600 МГц
Input LevelLVDS
Количество выходов8
Output Frequency(Max)1600 МГц
Output LevelLVDS, LVPECL
Package GroupWQFN
Package Size: mm2:W x L48WQFN: 49 mm2: 7 x 7(WQFN) PKG
VCC3.3 В
VCC Out3.3 В
  • Evaluation Modules & Boards: LMK01000EVAL
    1.6 GHz Low Noise Clock Buffer, Divider, and Distributor
  • AN-1821 CPRI Repeater System (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 26 апр 2013
    This application report implements the Common Public Radio Interface (CPRI) for Remote Radio Heads(RRHs). The designer can use this application report for developing CPRI-based repeater systems inpoint-to-point or multi-hop configurations. This application report consists of:Designs for the CPRI SerDes Repeater Boards for the Radio Equipment (RE) and Radio EquipmentController (REC)
  • Phase Synchronization with Multiple Devices and Frequencies (Rev. A)
    PDF, 199 Кб, Версия: A, Файл опубликован: 26 апр 2013
    This application note discusses how phase synchronization can be achieved when multiple chips are involved and also when the frequencies are not the same.
Серия: LMK01000 (3)
  • Semiconductors > Clock and Timing > Clock Buffers > Dividers
На английском языке: Datasheet Texas Instruments LMK01000ISQ/NOPB
