Datasheet Texas Instruments LMH1982SQX/NOPB — Даташит
СерияLMH1982
МодельLMH1982SQX/NOPB
Многоскоростной генератор видеосигналов с Genlock 32-WQFN от 0 до 70
LMH1982 Multi-Rate Video Clock Generator With Genlock datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 30 сен 2015
Тактовые генераторы и продукция для поддержки
LMH1982SQX/NOPB
1 423 ₽
LMH1982SQX/NOPB
1 904 ₽
HXD Co.
LMH1982SQX/NOPB
LMH1982SQX/NOPB
Pin32
Package TypeRTV
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY4500
МаркировкаL1982SQ
Width (мм)5
Length (мм)5
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Control InterfacePin/I2C
Formats SupportedNTSC,48-kHZ audio CLK,720p,576i/p,480i/p,1080i/p,PAL
FunctionClock Generator
Package GroupWQFN
Package Size: mm2:W x L32WQFN: 25 mm2: 5 x 5(WQFN) PKG
Power Consumption250 mW
Напряжение питания3.3,3.3 to 5 В
  • Evaluation Modules & Boards: ML571-1982CLK
    High-Performance SMPTE Video Clock Module for Xilinx ML571 Serial Digital Video Board
  • Evaluation Modules & Boards: LMH1982SQEEVAL
    LMH1982 Multi-Rate Video Clock Generator with LMH1981 HD/SD Video Sync Separator EVM
  • Triple Rate SDI IP FPGA Resource Utilization on SDXILEVK/AES-EXP-SDI-G Ref Dsgn (Rev. A)
    PDF, 50 Кб, Версия: A, Файл опубликован: 26 апр 2013
    Texas Instruments triple rate (SD/HD/3G) SDI demonstration board showcases the LMH0340 serializer,LMH0341 deserializer, LMH0344 equalizer, LMH1981 sync separator, LMH1982 clock generator withgenlock and the DS25CP104 cross-point switch. There are many advantages to using the TexasInstruments chipset that include superior performance, reduced cost using inexpensive FPGAs such asthe Xilinx S
  • Demonst SMPTE-Compliant SDI Out Jittr Using LMH1982 & Virtx-5 GTP Xmittr (Rev. A)
    PDF, 3.1 Мб, Версия: A, Файл опубликован: 26 апр 2013
    As 3-Gbps serial digital interface (SDI) gains adoption in professional and broadcast video equipment to enable fast-frame 1080p HD video over a single link, the need for flexible and high-performance video clock generation becomes critical to reliably transmit and receive triple-rate (3G/HD/SD) SDI video. This is especially true for multi-channel video equipment using SDI serializers and deserial
Серия: LMH1982 (3)
  • Semiconductors > Interface > SDI > SDI Video Timing
На английском языке: Datasheet Texas Instruments LMH1982SQX/NOPB
