Datasheet Texas Instruments DRV8872-Q1 — Даташит
Серия | DRV8872-Q1 |
Автомобильный драйвер матового двигателя постоянного тока 3,6 А с функцией оповещения о неисправностях
DRV8872-Q1 Automotive 3.6-A Brushed DC Motor Driver With Fault Reporting datasheet
PDF, 1.2 Мб, Файл опубликован: 30 ноя 2016
DRV8872-Q1 Texas Instruments | по запросу |
DRV8872DDARQ1 | |
Статус продукта | В производстве |
DRV8872DDARQ1 | |
N | 1 |
Pin | 8 |
Package Type | DDA |
Industry STD Term | HSOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 8872Q |
Width (мм) | 3.9 |
Length (мм) | 4.89 |
Thickness (мм) | 1.48 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.7 |
Mechanical Data | Скачать |
Parameters / Models | DRV8872DDARQ1![]() |
Additional Features | Current Regulation |
Control I/F | PWM |
Number of Full Bridges | 1 |
Number of Half Bridges | 2 |
Рабочий диапазон температур, C | от -40 до 125 |
Package Group | SO PowerPAD |
Package Size: mm2:W x L, PKG | 8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) |
Peak Output Current, A | 3.6 |
RDS(ON) (HS + LS), mOhms | 565 |
RMS Output Current, A | 2 |
Rating | Automotive |
Vs(Max), В | 45 |
Vs(Min), В | 6.5 |
DRV8872DDARQ1 | |
- Operating an Engine-Grille Shutter Motor With DRV8872-Q1PDF, 1.5 Мб, Файл опубликован: 1 дек 2016
The addition of an active grille shutter is a key aerodynamic improvement in recent model-year vehicles. Depending on the ambient temperature of the environment, the shutters behind the engine grille can open and close to increase the engine efficiency and reduce turbulent air from entering the engine, thereby reducing drag. The shutters can be operated by a brushed-DC (BDC) motor. A suitable devi
Серия: DRV8872-Q1 (1)
- Semiconductors> Motor Drivers> Brushed DC (BDC) Drivers> Brushed DC Drivers with FETs
