Datasheet Texas Instruments 5962-9221703M2A — Даташит
Серия | CY54FCT373T |
Модель | 5962-9221703M2A |
Восьмеричные прозрачные защелки типа D с выходами с 3 состояниями 20-LCCC от -55 до 125
8-Bit Latches datasheet
PDF, 678 Кб, Версия: B, Файл опубликован: 20 авг 2001
Купить 5962-9221703M2A на РадиоЛоцман.Цены — от 847 до 1 598 ₽ Octal Transparent D-Type Latches with 3-State Outputs 20-LCCC -55 to 125 | |||
5962-9221703M2A IDT | 847 ₽ | ||
5962-9221703M2A Renesas | 1 474 ₽ | ||
5962-9221703M2A Texas Instruments | 1 598 ₽ | ||
5962-9221703M2A Texas Instruments | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
- Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
Серия: CY54FCT373T (4)
- 5962-9221701MRA 5962-9221702MRA 5962-9221703M2A CY54FCT373ATDMB
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
59629221703M2A, 5962 9221703M2A
