Datasheet Texas Instruments CD54HCT173F3A — Даташит
Серия | CD54HCT173 |
Модель | CD54HCT173F3A |
Высокоскоростные КМОП-триггеры Logic Quad D-типа с выходами с 3 состояниями 16-CDIP от -55 до 125
CD54HC173, CD74HC173, CD54HCT173, CD74HCT173 datasheet
PDF, 923 Кб, Версия: E, Файл опубликован: 13 окт 2003
![]() 15 предложений от 15 поставщиков High Speed CMOS Logic Quad D-Type Flip-Flops with 3-State Outputs 16-CDIP -55 to 125 | |||
CD54HCT173F3A Harris | 751 ₽ | ||
CD54HCT173F3A Texas Instruments | 1 578 ₽ | ||
CD54HCT173F3A-886341901 Texas Instruments | 2 112 ₽ | ||
CD54HCT173F3A | по запросу |
Pin | 16 | 16 |
Package Type | J | J |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 5962-8875901EA | CD54HCT173F3A |
Width (мм) | 6.92 | 6.92 |
Length (мм) | 19.56 | 19.56 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
3-State Output | Yes |
Bits | 4 |
F @ Nom Voltage(Max) | 25 Mhz |
ICC @ Nom Voltage(Max) | 0.08 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 6/-6 мА |
Тип выхода | CMOS |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Technology Family | HCT |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 50 нс |
RoHS | See ti.com |
- Power-Up Behavior of Clocked Devices (Rev. A)PDF, 34 Кб, Версия: A, Файл опубликован: 6 фев 2015
- Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HCT173 (2)
- 5962-8875901EA CD54HCT173F3A
- Semiconductors > Space & High Reliability > Logic Products > Flip-Flop/Latch/Registers
