Источники питания Keen Side
Datasheet Texas Instruments CD54HC4051 — Даташит
СерияCD54HC4051
Высокоскоростные аналоговые мультиплексоры/демультиплексоры с КМОП-логикой
CDx4HC405x, CDx4HCT405x High-Speed CMOS Logic Analog Multiplexers and Demultiplexers datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 6 фев 2017
15 предложений от 15 поставщиков
High Speed CMOS Logic Analog Multiplexers/Demultiplexers 16-CDIP -55 to 125
T-electron
CD54HC4051F
1 284 ₽
CD54HC4051F
1 872 ₽
МосЧип
CD54HC4051F3
Allelco
CD54HC4051F
CD54HC4051FCD54HC4051F3A
N12
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC4051FCD54HC4051F3A
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Parameters / ModelsCD54HC4051F
CD54HC4051F
CD54HC4051F3A
CD54HC4051F3A
Additional FeaturesLow Power,Low Crosstalk,Break-before-makeLow Power,Low Crosstalk,Break-before-make
Bandwidth(Max), МГц180180
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Ron(Max), Ohms130130
Ron(Typ), Ohms4545
Schmitt TriggerNoNo
Technology FamilyHCHC
VCC(Max), В66
VCC(Min), В22
RoHSSee ti.comSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4051 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Switches and Multiplexer> Multiplexers/Demultiplexers (Mux/Demux)
На английском языке: Datasheet Texas Instruments CD54HC4051
