Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet Texas Instruments CD54HC4017 — Даташит
СерияCD54HC4017
Высокоскоростной КМОП-логический декадный счетчик/делитель с 10 декодированными выходами
Decade Counter/Divider With Ten Decoded Outputs datasheet
PDF, 208 Кб, Файл опубликован: 19 мар 1999
High-Speed CMOS Logic Decade Counter/Divider with 10 Decoded Outputs
Allelco
CD54HC4017F
Harris
CD54HC4017_07
МосЧип
CD54HC4017
8601101EACD54HC4017F3A
N12
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка8601101EA8601101EA
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Parameters / Models8601101EA
8601101EA
CD54HC4017F3A
CD54HC4017F3A
Bits1010
F @ Nom Voltage(Max), Mhz2828
FunctionCounterCounter
ICC @ Nom Voltage(Max), мА0.080.08
Рабочий диапазон температур, Cот -55 до 125от -55 до 125
Output Drive (IOL/IOH)(Max), мА5.2/-5.25.2/-5.2
Package GroupCDIPCDIP
Package Size: mm2:W x L, PKGSee datasheet (CDIP)See datasheet (CDIP)
RatingMilitaryMilitary
Schmitt TriggerNoNo
Technology FamilyHCHC
ТипDecadeDecade
VCC(Max), В66
VCC(Min), В22
Voltage(Nom), В3.3,53.3,5
tpd @ Nom Voltage(Max), нс5454
RoHSSee ti.comSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4017 (2)
  • Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC4017
