Datasheet Texas Instruments CD54ACT151 — Даташит
Серия | CD54ACT151 |
8-входовой мультиплексор
CD54ACT151, CD74ACT151 datasheet
PDF, 795 Кб, Файл опубликован: 7 мар 2003
Купить CD54ACT151F3A на РадиоЛоцман.Цены — от 18 до 1 430 ₽ 10 предложений от 9 поставщиков Multiplexer, ACT Series, 1-Func, 8 Line Input, 1 Line Output, Complementary Output, CMOS, CDIP16 | |||
CD54ACT151F/3A Harris | от 18 ₽ | ||
CD54ACT151F/3A Harris | 176 ₽ | ||
CD54ACT151F/3A Texas Instruments | по запросу | ||
CD54ACT151F3A** Texas Instruments | по запросу |
CD54ACT151F3A | |
Статус продукта | В производстве |
CD54ACT151F3A | |
N | 1 |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54ACT151F3A |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Parameters / Models | CD54ACT151F3A |
Количество каналов | 1 |
F @ Nom Voltage(Max), Mhz | 90 |
ICC @ Nom Voltage(Max), мА | 0.08 |
Рабочий диапазон температур, C | от -55 до 125 |
Package Group | CDIP |
Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ACT |
VCC(Max), В | 5.5 |
VCC(Min), В | 4.5 |
Voltage(Nom), В | 5 |
tpd @ Nom Voltage(Max), нс | 14.1 |
CD54ACT151F3A | |
RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54ACT151 (1)
- Semiconductors> Space & High Reliability> Logic Products> Specialty Logic Products> Decoders/Encoders/Multiplexers
