Datasheet Texas Instruments CD54ACT08 — Даташит
Серия | CD54ACT08 |
Четырехвходовые логические элементы И с 2 входами
Quadruple 2-Input Positive-AND Gates datasheet
PDF, 970 Кб, Версия: B, Файл опубликован: 12 июн 2002
Quad 2-Input AND Gate | |||
CD54ACT08E3A Texas Instruments | по запросу | ||
CD54ACT08 Texas Instruments | по запросу |
CD54ACT08F3A | |
Статус продукта | В производстве |
CD54ACT08F3A | |
N | 1 |
Pin | 14 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | CD54ACT08F3A |
Width (мм) | 6.67 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Parameters / Models | CD54ACT08F3A![]() |
Bits | 4 |
F @ Nom Voltage(Max), Mhz | 90 |
ICC @ Nom Voltage(Max), мА | 0.04 |
Тип входа | TTL |
Рабочий диапазон температур, C | от -55 до 125 |
Output Drive (IOL/IOH)(Max), мА | -24/24 |
Тип выхода | CMOS |
Package Group | CDIP |
Package Size: mm2:W x L, PKG | See datasheet (CDIP) |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ACT |
VCC(Max), В | 5.5 |
VCC(Min), В | 4.5 |
tpd @ Nom Voltage(Max), нс | 12.9 |
CD54ACT08F3A | |
RoHS | See ti.com |
- Selecting the Right Level Translation Solution (Rev. A)PDF, 313 Кб, Версия: A, Файл опубликован: 22 июн 2004
Supply voltages continue to migrate to lower nodes to support today's low-power high-performance applications. While some devices are capable of running at lower supply nodes others might not have this capability. To haveswitching compatibility between these devices the output of each driver must be compliant with the input of the receiver that it is driving. There are several level-translati - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Серия: CD54ACT08 (1)
- Semiconductors> Space & High Reliability> Logic Products> Gate Products
