Datasheet Texas Instruments CC2500-RTY1 — Даташит
СерияCC2500
МодельCC2500-RTY1
Low-Cost Low-Power 2.4 GHz RF Transceiver datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 19 май 2009
Радиочастотная деталь RF, Low Cost, Low-Power 2.4GHz RF Transceiver Designed for Low-Power Wireless Apps in the 2.4GHz ISM B 20-VQFN -40℃...
CC2500-RTY1
730 ₽
T-electron
CC2500-RTY1
CC2500-RTY1
CC2500-RTY1
Pin20
Package TypeRTK
Industry STD TermVQFNP
JEDEC CodeS-PQFP-N
МаркировкаCC2500
Width (мм)4
Length (мм)4
Thickness (мм).85
Pitch (мм).5
Max Height (мм).9
Approx. Price (US$)0.99 | 1ku
Data Rate(Max)(kbps)500
Device TypeSmart RF Transceiver
Key Software FeaturesSimpliciTI Supported
Max VCC3.6
Min VCC1.8
Modulation TechniquesOOK
2-FSK
GFSK
Operating Temperature Range(C)-40 to 85
RAM size(KB)1
2
4
RX Current (Lowest)(mA)13.3
Sensitivity (Best)(dBm)-104
TX Power(Max)(dBm)1
TechnologyProprietary 2.4 GHz
Throughput(Max)(Mbps)0.5
USB 2.0No
RoHSНе совместим
  • Evaluation Modules & Boards: SMARTRFTRXEBK
    SmartRF Transceiver Evaluation Board
  • Daughter Cards: CC2500EMK
    CC2500EMK Evaluation Module 2.4 GHz
  • Evaluation Modules & Boards: EZ430-RF2500T
    MSP430 2.4-GHz Wireless Target Board
  • Evaluation Modules & Boards: EZ430-RF2500-SEH
    MSP430 Solar Energy Harvesting Development Tool
  • Daughter Cards: BOOST-CCEMADAPTER
    EM Adapter BoosterPack
  • Development Kits: EZ430-RF2500
    MSP430 Wireless Development Tool
  • DN000 - Design Note Overview (Rev. T)
    PDF, 126 Кб, Версия: T, Файл опубликован: 12 окт 2011
  • AN003 -- SRD Antennas
    PDF, 358 Кб, Файл опубликован: 1 фев 2006
  • DN300 -- SmartRF04EB Troubleshooting (Rev. B)
    PDF, 490 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • AN048 -- 2.4GHz Chip Antenna (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 4 мар 2008
    This application note describes the performance and characteristics of the Compact Reach Xtendв„ў chip antenna. This antenna is specifically designed to operate at 2.4 GHz and combines small size with high performance to improve the functionality of RF devices.
  • AN085 -- Implementing Diversity Using Low Power Radios
    PDF, 459 Кб, Файл опубликован: 26 янв 2010
    CC1101, CC1110, CC2500, CC2510, CC430 Implementing 'Diversity' Using Low Power Radios
  • DN400 -- Interfacing CC1100 - CC2500 with MSP430 (Rev. A)
    PDF, 292 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • DN018 -- Range Measurements in an Open Field Environment (Rev. A)
    PDF, 607 Кб, Версия: A, Файл опубликован: 15 апр 2008
    This design note is a general description of how to set up open field range measurements and what has to be considered. Applies to all low power RF-ICs.
  • 2.4-GHz Inverted F Antenna (Rev. C)
    PDF, 470 Кб, Версия: C, Файл опубликован: 8 фев 2017
  • DN021 - CC2500 and CC2510 Sensitivity versus Frequency Offset and Crystal Accura
    PDF, 110 Кб, Файл опубликован: 10 мар 2008
    This design note provides plots from sensitivity versus frequency offset measurements for different data rates on the CC2500 device. The results are also applicable for CC2510/CC2511. The required crystal accuracy is calculated from these plots.
  • DN507 -- FEC Decoding
    PDF, 264 Кб, Файл опубликован: 28 янв 2010
    The purpose of this design note is to show how the FEC decoding implemented in HW on the CC1100, CC1100E, CC1101, CC1110Fx, CC1111Fx, CC1150, CC2500, CC2510Fx, CC2511Fx, and CC2550 can be implemented in SW. This is in particular very important for the CC430Fx device, which has the same radio as the CC1101 and CC1110/11Fx but without HW FEC included.
  • DN509 -- Data Whitening and Random TX Mode
    PDF, 183 Кб, Файл опубликован: 12 апр 2010
    This document gives an overview of the data whitening and random data transmission circuitry in the CC430, CC1100, CC1100E, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices.
  • AN095 -- Continuous Data Streaming Applications - Using Serial Synchronous Mode (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 18 июл 2011
  • AN032 -- 2.4 GHz Regulations
    PDF, 332 Кб, Файл опубликован: 31 янв 2006
  • DN303 -- Cleanup of Installed PC Tools
    PDF, 545 Кб, Файл опубликован: 20 дек 2006
  • AN058 -- Antenna Selection Guide (Rev. B)
    PDF, 1.8 Мб, Версия: B, Файл опубликован: 6 окт 2010
  • DN111 - Current Consumption for a Polling Receiver (Rev. A)
    PDF, 687 Кб, Версия: A, Файл опубликован: 24 мар 2009
  • AN103 -- Basic RF Testing of CCxxxx Devices
    PDF, 596 Кб, Файл опубликован: 8 авг 2011
    This document presents users of Texas Instruments' low-power RF products with an overview of the different characterization tests (conducted, not radiated) that are performed during the device verification process. The document covers the basic setup of the test system and gives procedural information about each test.
  • DN503 -- SPI Access (Rev. B)
    PDF, 94 Кб, Версия: B, Файл опубликован: 22 окт 2007
    The purpose of this design note is to show how the serial peripheral interface (SPI) must be configured to be able to communicate with the CC1100/CC1101/CC1150/CC2500/CC2550. It also shows how the status bytes should be interpreted and how SW reset is done over the SPI interface.
  • DN014 -- Programming Output Powers on CC2500 and CC2550
    PDF, 176 Кб, Файл опубликован: 4 окт 2007
    This document gives a complete overview of the register settings required to adjust the output power of the CC2500 and CC2550 devices. The tables within this document include typical output power, harmonics, and current consumption at the different register settings.
  • DN504 -- FEC Implementation (Rev. A)
    PDF, 110 Кб, Версия: A, Файл опубликован: 22 окт 2007
    This design note explains the functionality of forward error correction (FEC) and how it is used in the CC1100, CC1101, CC1110, CC1111, CC1150, CC2500, CC2510, CC2511, and CC2550 devices. Example code for FEC implementation is included.
  • DN502 -- CRC Implementation (Rev. D)
    PDF, 55 Кб, Версия: D, Файл опубликован: 27 окт 2009
  • Clear Channel Assessment Using TI MSP430 and CC2500 Radio
    PDF, 950 Кб, Файл опубликован: 31 июл 2007
    This application report describes a 2.4-GHz anti-jamming frequency-hopping system consisting of a designated Transmitter and Receiver, each with distinct functions to avoid RF-channel interference. The Transmitter board emulates the control device (e.g., remote control) by sending commands to be processed on the Receiver side (e.g., TV, stereo, set top box, or gaming console). Since many popular c
  • DN011 -- RF Module Testing using SmartRF Studio (Rev. A)
    PDF, 325 Кб, Версия: A, Файл опубликован: 23 мар 2009
  • DN002 -- Practical Sensitivity Testing
    PDF, 364 Кб, Файл опубликован: 20 дек 2006
  • DN004 Folded Dipole Antenna for CCC25xx
    PDF, 383 Кб, Файл опубликован: 5 дек 2006
    DN00x Folded Dipole Antenna for CCC25xx
  • AN028 -- LC Filter with Improved High-Frequency Attenuation
    PDF, 254 Кб, Файл опубликован: 1 фев 2006
    AN028 -- Improved LC Filter
  • AN049 -- Software for CC1100/CC2500 and MSP430 – Examples and Function Library
    PDF, 485 Кб, Файл опубликован: 31 май 2007
    The Software for CC1100/CC2500 and MSP430 - Examples and Function Library is the recommended starting point for developing software for the CC1100/CC2500 and MSP430 combination.The software demonstrates how to use some of the many advanced digital features and packet handling capabilities of the CC1100/CC2500. The software examples have been developed for the MSP430 Experimenter’s Board, but c
  • DN034 -- YAGI 2.4 GHz PCB Antenna
    PDF, 1.9 Мб, Файл опубликован: 14 окт 2010
  • AN098 - Layout Review Techniques for Low Power RF Designs (Rev. A)
    PDF, 456 Кб, Версия: A, Файл опубликован: 2 авг 2012
  • DN035 -- Antenna Quick Guide (Rev. A)
    PDF, 138 Кб, Версия: A, Файл опубликован: 12 фев 2013
  • AN043 -- Small Size 2.4 GHz PCB Antenna (Rev. D)
    PDF, 2.3 Мб, Версия: D, Файл опубликован: 4 апр 2008
  • DN031 -- CC-Antenna-DK Documentation and Antenna Measurements Summary
    PDF, 2.3 Мб, Файл опубликован: 26 авг 2010
    DN031 -- Design Notes
  • DN506 -- GDO Pin Usage (Rev. A)
    PDF, 219 Кб, Версия: A, Файл опубликован: 22 окт 2007
    The purpose of this design note is to explain how to use the different general digital output (GDO) pins for control and monitoring purposes. The focus is set on interfacing with a microcontroller unit (MCU) and is related to the CC1100, CC1101, CC1150, CC2500 and CC2550 devices.
  • AN068 - Design Steps and Results for Changing PCB Layer Thickness (Rev. A)
    PDF, 792 Кб, Версия: A, Файл опубликован: 8 окт 2009
  • DN501 -- PATABLE Access (Rev. B)
    PDF, 66 Кб, Версия: B, Файл опубликован: 24 мар 2009
  • DN500 -- Packet Transmission Basics (Rev. C)
    PDF, 174 Кб, Версия: C, Файл опубликован: 6 апр 2009
  • AN047 -- CC1100/CC2500 Wake on Radio (Rev. B)
    PDF, 220 Кб, Версия: B, Файл опубликован: 23 мар 2009
    AN047--CC1100/CC2500 Wake on Radio
  • DN505 -- RSSI interpretation and timing (Rev. D)
    PDF, 129 Кб, Версия: D, Файл опубликован: 16 июн 2010
  • AN021 -- Voltage Level Conversion
    PDF, 212 Кб, Файл опубликован: 1 фев 2006
  • AN014 -- Frequency Hopping Systems
    PDF, 210 Кб, Файл опубликован: 1 фев 2006
  • DN019 -- Powering Low-Power RF Products (Rev. B)
    PDF, 327 Кб, Версия: B, Файл опубликован: 18 сен 2009
  • Semiconductors > Wireless Connectivity > Proprietary 2.4 GHz
CC2500RTY1, CC2500 RTY1
На английском языке: Datasheet Texas Instruments CC2500-RTY1
