Datasheet Texas Instruments BQ76PL102RGTT — Даташит
СерияBQ76PL102
МодельBQ76PL102RGTT
Монитор двухэлементной литий-ионной батареи PowerLAN с балансировкой ячеек PowerPump 16-VQFN от -40 до 85
PowerLAN Dual-Cell Li-Ion Monitor with PowerPump Cell Balancing datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 15 окт 2009
32 предложений от 13 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Управление батареями
LIXINC Electronics
BQ76PL102RGTT
от 5.28 ₽
BQ76PL102RGTT
100 ₽
ЭИК
BQ76PL102RGTT
от 915 ₽
BQ76PL102RGTT
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаOAG
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
  • Quick-Start Guide for BQ78PL114 with BQ76PL102 Family Gas Gauges
    PDF, 4.1 Мб, Файл опубликован: 26 апр 2010
    This application report gives an overview of the implementation and testing of Texas Instruments bq78PL114 with companion bq76PL102 high-cell-count battery gas gauge and protector. It explores the hardware and software graphical user interface (GUI) setup.
  • bq78PL114 System Design Guidelines
    PDF, 9.6 Мб, Файл опубликован: 1 дек 2009
    This application report provides a system-level functional description of the bq78PL114 circuitry and describes recommended system design and printed-circuit board layout techniques to ensure best performance.
  • PowerPump(TM) Balancing (Rev. B)
    PDF, 721 Кб, Версия: B, Файл опубликован: 26 окт 2011
    Pack based charging and discharging schemes cannot fully address the problems associated with capacity imbalance of the series cells. Balancing at the cell level is needed to maximize pack performance. PowerPumpв„ў Cell Balancing is a feature provided in the bq78PL114 and bq76PL102 PowerLANв„ў devices that transfers charge between cells using a boost-type power converter topology. Results are faster a
Серия: BQ76PL102 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76PL102RGTT
