Datasheet Texas Instruments BQ29330DBTRG4 — Даташит
СерияBQ29330
МодельBQ29330DBTRG4
Защита двух-, трех- и четырехэлементных литиевых или литий-полимерных батарей AFE 30-TSSOP от -40 до 110
2, 3-, 4-Cell Lithium-Ion or Lithium-Polymer Battery Protection AFE datasheet
PDF, 1.0 Мб, Версия: E, Файл опубликован: 19 мар 2012
Battery Protection Li-Ion 50mA 25V 30Pin TSSOP T/R
BQ29330DBTRG4
88 ₽
T-electron
BQ29330DBTRG4
114 ₽
BQ29330DBTRG4
908 ₽
BQ29330DBTRG4
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
Маркировка29330
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Evaluation Modules & Boards: BQ20Z90EVM-001
    BQ20Z90EVM Evaluation Module for 2nd Generation Impedance TrackВ™
  • Evaluation Modules & Boards: BQ20Z40EVM-001
    BQ20Z40EVM-001 SBS 1.1 Impedance TrackВ™ Tech Enabled Battery Mgmt Solution Kit
    Статус продукта: NRND (Не рекомендуется для новых разработок)
  • bq29330 External Short Circuit Protection
    PDF, 155 Кб, Файл опубликован: 22 авг 2007
    In Li-ion battery pack design, short-circuit protection should be given sufficient emphasis to ensure that even if an external pack short does occur, it is benign. Properly designed battery fuel gauge solutions using the bq29330 analog front-end (AFE) protector and bq20z70, bq20z75, bq20z90, and bq20z95 fuel gauge ICs not only safeguards the battery, but also ensures a full recovery of functionali
  • Fast Cell Balancing Using External MOSFET (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 26 янв 2009
    The need for cell balancing comes from the fact that cell-to-cell differences in self-discharge, capacity, and impedance can lead to different charge states among the cells. However, the charger terminates the charge based on the summed voltage only, which may leave some cells undercharged and others overcharged. To remedy this imbalance and to achieve the goal of having all cells reaching 100% st
Серия: BQ29330 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ29330DBTRG4
