Datasheet Texas Instruments AMC1305M25QDWQ1 — Даташит
Серия | AMC1305M25-Q1 |
Модель | AMC1305M25QDWQ1 |
Automotive Reinforced Isolated Modulator With В±250mV Input and CMOS Interface 16-SOIC -40 to 125
AMC1305x-Q1 High-Precision, Reinforced Isolated Delta-Sigma Modulators datasheet
PDF, 1.6 Мб, Файл опубликован: 9 фев 2017
![]() 7 предложений от 7 поставщиков , Single Channel Single ADC Delta-Sigma 20MSPS 16Bit Serial CMOS Automotive 16Pin SOIC Tube | |||
AMC1305M25QDWQ1 Texas Instruments | 581 ₽ | ||
AMC1305M25QDWQ1 Texas Instruments | 695 ₽ | ||
AMC1305M25QDWQ1 | 41 068 ₽ |
Pin | 16 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 40 |
Carrier | TUBE |
Маркировка | 1305M25Q1 |
Width (мм) | 7.5 |
Length (мм) | 10.3 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Voltage AVDD(Max) | 5.5 В |
Analog Voltage AVDD(Min) | 4.5 В |
Архитектура | Delta-Sigma |
CMTI(Min) | 15 kV/µs |
Digital Supply(Max) | 5.5 В |
Digital Supply(Min) | 3 В |
INL(Max) | 4 +/-LSB |
Input Range | 250mV Vp-p |
Interface | Serial CMOS |
Isolation | 7 kV peak |
Package Group | SOIC |
Package Size: mm2:W x L | 16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG |
Power Consumption(Typ) | 36.1 mW |
Rating | Automotive |
Разрешение | 16 Bits |
SFDR | 92 дБ |
SINAD | 84 дБ |
SNR | 85 дБ |
Sample Rate (max) | 20MSPS SPS |
Sample Rate(Max) | 2 MSPS |
THD(Max) | -83 дБ |
- Evaluation Modules & Boards: AMC1305M25EVM
AMC1305M25 Isolated Single-Channel Delta-Sigma Modulator Evaluation Module
Серия: AMC1305M25-Q1 (2)
- AMC1305M25QDWQ1 AMC1305M25QDWRQ1
- Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > Isolated ADCs
