Datasheet Texas Instruments TCA6416ARTWR — Даташит
Серия | TCA6416A |
Модель | TCA6416ARTWR |
Низковольтный 16-разрядный расширитель ввода-вывода I2C и SMBus 24-WQFN от -40 до 85
TCA6416A Low-Voltage 16-Bit I2C and SMBus I/O Expander With Voltage Translation, Interrupt Output, Reset Input, and Configuration Registers datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 8 авг 2017
Купить TCA6416ARTWR на РадиоЛоцман.Цены — от 62 до 596 ₽ 35 предложений от 15 поставщиков Интегральные микросхемы Интерфейс - Расширители портов ввода/вывода | |||
TCA6416ARTWR Texas Instruments | от 62 ₽ | ||
TCA6416ARTWR Texas Instruments | 68 ₽ | ||
TCA6416ARTWR Texas Instruments | от 170 ₽ | ||
TCA6416ARTWR Texas Instruments | по запросу |
Pin | 24 |
Package Type | RTW |
Industry STD Term | WQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | PH416A |
Width (мм) | 4 |
Length (мм) | 4 |
Thickness (мм) | .75 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
I2C Address | 0100 00x |
Max Frequency | 400 kHz |
Number of I/Os | 16 |
Package Group | WQFN |
Rating | Catalog |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage Nodes | 1.8,2.7,3.3,3.6,5 В |
fSCLK(Max) | 0.4 МГц |
- Evaluation Modules & Boards: IO-EXPANDER-EVM
IO-EXPANDER-EVM: I2C and SMBus IO Expander Evaluation Module
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TCA6416A (3)
- TCA6416APWR TCA6416ARTWR TCA6416AZQSR
- Semiconductors > Interface > I2C > I2C General Purpose I/O (GPIO)
