Datasheet Texas Instruments UC2846J — Даташит
Серия | UC2846M |
Модель | UC2846J |
ШИМ-контроллер текущего режима 16-CDIP от -40 до 85
UCx846/7 Current Mode PWM Controller datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 4 янв 2016
Купить UC2846J на РадиоЛоцман.Цены — от 1 611 до 2 514 ₽ 12 предложений от 12 поставщиков Switching Controller, Current-mode, 0.5A, 500kHz Switching Freq-Max, BIPolar, CDIP16, DIP-16 | |||
UC2846J Texas Instruments | 1 611 ₽ | ||
UC2846J Unitrode | 2 023 ₽ | ||
UC2846J Texas Instruments | 2 514 ₽ | ||
UC2846J Unitrode | по запросу |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | UC2846J |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 50 % |
Frequency(Max) | 500 kHz |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Special Features | Error Amplifier,Soft Start,Synchronization Pin,Multi-topology |
Topology | Boost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 7.7/6.95 В |
Vin(Max) | 40 В |
Vin(Min) | 7 В |
RoHS | See ti.com |
- Modeling Analysis and Compensation of the Current-Mode ConverterPDF, 189 Кб, Файл опубликован: 5 сен 1999
As current-mode conversion increases in popularity several peculiarities associated with fixed-frequency peak-current detecting schemes have surfaced. These include instability above 50% duty cycle a tendency towards subharmonic oscillation non-ideal loop response and an increased sensitivity to noise. This application note attempts to show that the performance of any current-mode converter c - U-93 A New Integrated Circuit for Current Mode ControlPDF, 411 Кб, Файл опубликован: 5 сен 1999
Advantages of current-mode control over conventional PWM approaches to switching power converters include automatic feed-forward automatic symmetry correction inherent current-limiting simple loop-compensation enhanced load-response and the capability for parallel operation. This application note introduces the first control integrated circuit specifically designed for this topology defines - DN-45 UC3846 UC3856 and UCC3806 Push Pull PWM Current Mode Control ICsPDF, 27 Кб, Файл опубликован: 5 сен 1999
The UC3856 is a pin-for-pin-compatible high-performance bipolar version of the industry standard UC3846. It can replace the UC3846 with few circuit modifications and it features increased speed higher gate-drive current and reduced propagation delays. The UCC3806 is a BiCMOS pin-for-pin compatible ultra-low-power version ideal for battery low-power and high-speed applications. The UCC3806 - DN-62 Switching Power Supply Topology Voltage Mode vs. Current ModePDF, 66 Кб, Файл опубликован: 5 сен 1999
This design note explains the differences between voltage-mode and current-mode switching power supply topologies. It includes a circuit diagram for each mode and suggests criteria for choosing which mode to use.
Серия: UC2846M (1)
- UC2846J
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
