Datasheet Texas Instruments LMH6646 MDC — Даташит
СерияLMH6646
МодельLMH6646 MDC
2.7V, 650ВµA, 55MHz Rail-to-Rail Input and Output Amplifiers with Shutdown Option 0-DIESALE -40 to 85
LMH664x 2.7 V, 650 uA, 55 MHz, Rail-to-Rail I/O Amplifiers w/Shutdown Option datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 ноя 2014
LifeElectronics
LMH6646MDC----CALLREPпо запросу
Package TypeY
Package QTY374
2nd Harmonic(dBc)62
3rd Harmonic(dBc)72
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)0.88 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)55
CMRR(Min)(dB)60
CMRR(Typ)(dB)84
GBW(Typ)(MHz)55
Input Bias Current(Max)(pA)2000000
Iq per channel(Max)(mA)1.6
Iq per channel(Typ)(mA)0.725
Number of Channels(#)2
Offset Drift(Typ)(uV/C)5
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)20
Package GroupDIESALE
Package Size: mm2:W x L (PKG)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)22
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.5
Vn at Flatband(Typ)(nV/rtHz)17
Vos (Offset Voltage @ 25C)(Max)(mV)3
  • Evaluation Modules & Boards: LMH730123
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LMH6646 MDC
