Клеммные колодки Keen Side
Datasheet Texas Instruments SNJ54AS645FK — Даташит
СерияSN54AS645
МодельSNJ54AS645FK
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-LCCC от -55 до 125
Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.2 Мб, Файл опубликован: 1 янв 1995
OCTAL BUS TRANSCEIVERS WITH 3-STATE OUTPUTS
МосЧип
SNJ54AS645FK
Pin20
Package TypeFK
Industry STD TermLCCC
JEDEC CodeS-CQCC-N
Width (мм)8.89
Length (мм)8.89
Thickness (мм)1.83
Max Height (мм)2.03
Operating Temperature Range(C)-55 to 125
Package GroupCDIP
Package Size: mm2:W x L (PKG)See datasheet (CFP)
See datasheet (CDIP)
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)(V)5.5
VCC(Min)(V)4.5
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
Серия: SN54AS645 (3)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
На английском языке: Datasheet Texas Instruments SNJ54AS645FK
