Datasheet Texas Instruments SN74LVC10AD — Даташит
СерияSN74LVC10A
МодельSN74LVC10AD
Тройной логический элемент положительного NAND с 3 входами, 14-SOIC, от -40 до 125
SN74LVC10A datasheet
PDF, 996 Кб, Версия: O, Файл опубликован: 27 июл 2005
38 предложений от 18 поставщиков
Микросхема Логический чип, TEXAS INSTRUMENTS SN74LVC10AD NAND Gate, LVC Family, 3Input, 24mA, 4.9ns, 1.65V to 3.6V, SOIC-14
ИМЭК
Россия и страны ТС
SN74LVC10AD
22 ₽
SN74LVC10AD
36 ₽
SN74LVC10AD
80 ₽
SN74LVC10AD
Pin14
Package TypeD
Package QTY50
МаркировкаLVC10A
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
Bits3
F @ Nom Voltage(Max)150 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)24/-24 мА
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)10.6,7.8,5.8,4.9 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > NAND Gate
На английском языке: Datasheet Texas Instruments SN74LVC10AD
