Datasheet Texas Instruments TLV2472CDRG4 — Даташит
Серия | TLV2472 |
Модель | TLV2472CDRG4 |
Двойной операционный усилитель Rail-to-Rail малой мощности, 8-SOIC, от 0 до 70
Family of 600uA/Ch 2.8MHz Rail-to-Rail I/O High-Drive Op Amps with Shutdown datasheet
PDF, 2.9 Мб, Версия: E, Файл опубликован: 3 июл 2007
![]() 10 предложений от 10 поставщиков Микросхема Операционный усилитель, OP Amp Dual GP R-R I/O ±3V/6V 8Pin SOIC T/R | |||
TLV2472CDRG4 Texas Instruments | 71 ₽ | ||
TLV2472CDRG4 Texas Instruments | 80 ₽ | ||
TLV2472CDRG4 Texas Instruments | 93 ₽ | ||
TLV2472CDRG4 | по запросу |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 2472C |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 64 дБ |
CMRR(Typ) | 84 дБ |
GBW(Typ) | 2.8 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 0.9 мА |
Iq per channel(Typ) | 0.6 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.4 uV/C |
Рабочий диапазон температур | от -40 до 125,0 до 70 C |
Output Current(Typ) | 90 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 1.5 V/us |
Total Supply Voltage(Max) | 6 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.7 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 15 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 2.2 мВ |
- Thermistor Temperature Transducer to ADC ApplicationPDF, 74 Кб, Файл опубликован: 22 сен 2000
An interchangeable-thermistor temperature-measurement application is described and a basic framework circuit which can be modified to use alternative components is provided. When a potentiometer is used instead of a thermistor, the application can also be used to measure other process variables. A basic understanding of active and passive analog devices is assumed. - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2472 (17)
