Datasheet Texas Instruments TPA2001D1PWR — Даташит
СерияTPA2001D1
МодельTPA2001D1PWR
Моноусилитель звука класса D 1 Вт 16-TSSOP от -40 до 85
1-W Filterless Mono Class-D Audio Power Amplifier datasheet
PDF, 588 Кб, Версия: D, Файл опубликован: 9 дек 2002
31 предложений от 16 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Speaker 1CH Mono 1W Class-D 16Pin TSSOP T/R
TPA2001D1PWR
от 27 ₽
TPA2001D1PWR
от 78 ₽
TPA2001D1PWR
174 ₽
ЭИК
TPA2001D1PWR
от 217 ₽
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка2001D1
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Analog Supply (V)5.5 Min
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceGPIO
Iq per channel(Typ)4 мА
Iq(Max)6 мА
Iq(Typ)4 мА
Load(Min)8 ohms
Выходная мощность1 W
PSRR72 дБ
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Pin/Package16TSSOP
Shutdown Current (ISD)0.05 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.1 %
  • Measuring Class-D Amplifiers for Audio Speaker Overstress Testing
    PDF, 175 Кб, Файл опубликован: 28 окт 2005
    This application report presents the results of an experiment conducted to demonstrate how to address the two most common concerns regarding speaker damage using Class-D amplifiers.
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2001D1 (4)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2001D1PWR
