Datasheet Texas Instruments LMT85LP — Даташит
Серия | LMT85 |
Модель | LMT85LP |
Датчик температуры с аналоговым выходом 1,8 В, 10 мкА в SC70 и TO-92 3-TO-92 от -50 до 150
LMT85, LMT85-Q1 1.8-V, SC70/TO-92/TO-92S, Analog Temperature Sensors datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 23 июн 2017
![]() 45 предложений от 14 поставщиков Датчики Температуры, TEXAS INSTRUMENTS LMT85LP Temperature Sensor IC, Analogue, ± 0.4℃, -50℃, 150℃, TO-92, 3Pins | |||
LMT85LP | от 15 ₽ | ||
LMT85LP Texas Instruments | 22 ₽ | ||
LMT85LP Texas Instruments | 135 ₽ | ||
LMT85LP Texas Instruments | от 146 ₽ |
Pin | 3 |
Package Type | LP |
Industry STD Term | TO-92 |
JEDEC Code | O-PBCY-W |
Package QTY | 1800 |
Carrier | LARGE T&R |
Маркировка | LMT85 |
Width (мм) | 4.3 |
Length (мм) | 4.3 |
Thickness (мм) | 3.6 |
Pitch (мм) | 1.27 |
Max Height (мм) | 5.34 |
Mechanical Data | Скачать |
Interface | Analog Output |
Local Sensor Accuracy(Max) | 2.7 +/- C |
Рабочий диапазон температур | от -50 до 150 C |
Package Group | TO-92 |
Package Size: mm2:W x L | 3TO-92: 13 mm2: 3.15 x 4(TO-92) PKG |
Rating | Catalog |
Sensor Gain | -8.2 mV/Deg C |
Special Features | Industry standard pinout |
Supply Current(Max) | 8.1 uA |
Supply Voltage(Max) | 5.5 В |
Supply Voltage(Min) | 1.8 В |
- Evaluation Modules & Boards: LMT84-7EVM
EVM for LMT84, LMT85, LMT86 and LMT87 Temperature Sensor
- SC Temp Sensors Challenge Precision RTDs and Thermistors in Build AutomationPDF, 247 Кб, Файл опубликован: 21 апр 2015
Standalone semiconductor sensors have rarely been considered for implementation into sensor probes or assemblies due to their larger geometries. However, advances in process technology and design have led to new, tiny sensor structures with almost linear transfer functions.In order to provide system designers with this new low-cost alternative to precision temperature measurement, this appl
- Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
