Datasheet Texas Instruments SN74ALVCHS162830DBBR — Даташит
Серия | SN74ALVCHS162830 |
Модель | SN74ALVCHS162830DBBR |
Драйвер адреса от 1 до 2 бит с выходами с 3 состояниями 80-TSSOP от -40 до 85
SN74ALVCHS162830 datasheet
PDF, 297 Кб, Версия: H, Файл опубликован: 10 сен 2004
1-Bit to 2-Bit Address Driver With 3-State Outputs 80-TSSOP -40 to 85 | |||
SN74ALVCHS162830DBBR Texas Instruments | по запросу | ||
Pin | 80 |
Package Type | DBB |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 6.1 |
Length (мм) | 17 |
Thickness (мм) | 1.15 |
Pitch (мм) | .4 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | SN74ALVCHS162830GR |
Replacement Code | S |
Approx. Price (US$) | 2.12 | 1ku |
Bits(#) | 2 |
F @ Nom Voltage(Max)(Mhz) | 100 |
ICC @ Nom Voltage(Max)(mA) | 0.4 |
Тип входа | LVTTL |
Operating Temperature Range(C) | -40 to 85 |
Output Drive (IOL/IOH)(Max)(mA) | -12/12 |
Тип выхода | LVTTL |
Package Group | TSSOP |
Package Size: mm2:W x L (PKG) | 80TSSOP: 138 mm2: 8.1 x 17(TSSOP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ALVC |
VCC(Max)(V) | 3.6 |
VCC(Min)(V) | 1.65 |
Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
tpd @ Nom Voltage(Max)(ns) | 3.8 4 3.5 |
RoHS | Не совместим |
- TI SN74ALVC16835 Component Specification Analysis for PC100PDF, 43 Кб, Файл опубликован: 3 авг 1998
The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T - Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large - Bus-Hold CircuitPDF, 418 Кб, Файл опубликован: 5 фев 2001
When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of - 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
Серия: SN74ALVCHS162830 (2)
- SN74ALVCHS162830DBBR SN74ALVCHS162830GR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
