Datasheet Texas Instruments SN74LVC08APWLE — Даташит
СерияSN74LVC08A
МодельSN74LVC08APWLE
Четырехканальный логический элемент «И» с 2 входами 14-TSSOP от -40 до 125
SN74LVC08A Quadruple 2-Input Positive-AND Gates datasheet
PDF, 1.4 Мб, Версия: S, Файл опубликован: 11 авг 2015
Quadruple 2-Input Positive-AND Gate 14-TSSOP -40 to 125
Элитан
SN74LVC08APWLE
36 ₽
SN74LVC08APWLE
SN74LVC08APWLE
727GS
SN74LVC08APWLE
Pin14
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementSN74LVC08APWR
Replacement CodeS
Approx. Price (US$)0.08 | 1ku
Bits(#)4
F @ Nom Voltage(Max)(Mhz)70
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаTTL
Operating Temperature Range(C)-40 to 125
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаTTL
Package GroupTSSOP
Package Size: mm2:W x L (PKG)14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)9.8
6.9
4.8
4.1
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Gate > AND Gate
На английском языке: Datasheet Texas Instruments SN74LVC08APWLE
