Datasheet Texas Instruments TLC2652C-14D — Даташит
Серия | TLC2652 |
Модель | TLC2652C-14D |
Прецизионный операционный усилитель со стабилизацией прерывателем 14-SOIC
TLC2652, TLC2652A, TLC2652Y Advanced LinCMOS Precision Chopper-Stabilized Op Amp datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 9 фев 2005
![]() 11 предложений от 11 поставщиков Микросхема Операционный усилитель, Precision Chopper-Stabilized Operational Amplifier 14-SOIC | |||
TLC2652C-14D Texas Instruments | 58 ₽ | ||
TLC2652C-14D Texas Instruments | 117 ₽ | ||
TLC2652C-14D Texas Instruments | 147 ₽ | ||
TLC2652C-14D Texas Instruments | 364 ₽ |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Additional Features | Zero Drift |
Approx. Price (US$) | 2.54 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 120 |
CMRR(Typ)(dB) | 140 |
GBW(Typ)(MHz) | 1.9 |
Input Bias Current(Max)(pA) | 60 |
Iq per channel(Max)(mA) | 2.4 |
Iq per channel(Typ)(mA) | 1.5 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 0.01 |
Operating Temperature Range(C) | -40 to 125 |
Output Current(Typ)(mA) | 3 |
Package Group | SOIC |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In to V- Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 2.8 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 16 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 3.8 |
Vn at 1kHz(Typ)(nV/rtHz) | 23 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 0.003 |
RoHS | Не совместим |
- AB-174: Getting the Full Potential from your ADC (Rev. A)PDF, 72 Кб, Версия: A, Файл опубликован: 28 июн 2002
Many of today?s high-resolution ADCs (Analog-to-Digital Converters) are operating from a single supply and use fully differential inputs. This can be a problem for single-ended signals that are bipolar relative to common. This article illustrates circuit configurations that preserve the full-scale input range by using modern features, such as Programmable Gain Amplifiers (PGAs) and internal voltag - Choosing an ADC and Op Amp for Minimum OffsetPDF, 72 Кб, Файл опубликован: 28 окт 1999
Designing a mixed-signal circuit containing analog and digital components can be a challenge to the development engineer. Requirements such as a low single-polarity supply voltage and a high degree of precision may conflict, and make the choice of components and the best circuit design difficult. This report discusses problems that arise in using operational amplifiers (op amps) for signal conditi
Серия: TLC2652 (13)
TLC2652C14D, TLC2652C 14D
