Datasheet Texas Instruments OPA861IDRG4 — Даташит
СерияOPA861
МодельOPA861IDRG4
Широкополосный операционный усилитель крутизны 8-SOIC от -40 до 85
Wide Bandwidth Operational Transconductance Amplifier (OTA) datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 14 май 2013
OPA861IDRG4
68 ₽
OPA861IDRG4
305 ₽
LifeElectronics
OPA861IDRG4
IC Home
OPA861IDRG4
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain(V/V)1
Approx. Price (US$)2.33 | 100u
BW @ Acl(MHz)80
GBW(Typ)(MHz)400
IIB(Max)(nA)1000
Iq per channel(Max)(mA)5.4
Number of Channels(#)1
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)15
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Slew Rate(Typ)(V/us)900
Vn at Flatband(Typ)(nV/rtHz)2.4
Vos(Max)(mV)12
Vs(Max)(V)12.6
Vs(Min)(V)4
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OTA-SO-1A
    Unpopulated PCB Compatible w/Wide Bandwidth Transconductance Op Amps in 8-lead SOIC (D) Pkg
  • Demystifying the Operational Transconductance Amplifier (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 16 апр 2013
    Operational transconductance amplifiers (OTAs) are often among the least understood analog components. However, these devices serve a very useful function that is being implemented on a regular basis in many integrated circuits as an element for more advanced purposes; the current feedback amplifier is among the most prominent example. The purpose of this application report is to show how this bui
  • Semiconductors > Amplifiers > Special Function Amplifiers > Transconductance Amplifiers
На английском языке: Datasheet Texas Instruments OPA861IDRG4
