Datasheet Texas Instruments SN74LVT162244ADLR — Даташит
СерияSN74LVT162244A
МодельSN74LVT162244ADLR
16-битные буферы/драйверы ABT 3,3 В с выходами с 3 состояниями 48-SSOP от -40 до 85
SN54LVT162244A, SN74LVT162244A datasheet
PDF, 934 Кб, Версия: D, Файл опубликован: 1 дек 2006
28 предложений от 14 поставщиков
Микросхема Логический чип, 3.3V ABT 16Bit Buffers/Drivers With 3-State Outputs 48-SSOP -40℃ to 85℃
SN74LVT162244ADLR
от 77 ₽
SN74LVT162244ADLR
84 ₽
SN74LVT162244ADLR
от 207 ₽
727GS
SN74LVT162244ADLR
от 258 ₽
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаLVT162244A
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.005 мА
Output Drive (IOL/IOH)(Max)-12/12 мА
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
Voltage(Nom)3.3 В
tpd @ Nom Voltage(Max)4 нс
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
На английском языке: Datasheet Texas Instruments SN74LVT162244ADLR
