Клеммные колодки Keen Side
Datasheet Texas Instruments TPA3007D1PWR — Даташит
СерияTPA3007D1
МодельTPA3007D1PWR
Моноусилитель мощности звука класса D, 6,5 Вт (TPA3007), 24-TSSOP от -40 до 85
6.5-W Mono Class-D Audio Power Amplifier datasheet
PDF, 648 Кб, Версия: D, Файл опубликован: 3 мар 2008
31 предложений от 16 поставщиков
Микросхема Усилитель звуковой частоты, TEXAS INSTRUMENTS TPA3007D1PWR Audio Power Amplifier, D, 1Channel, 6.5W, 8V to 18V, TSSOP, 24Pins
TPA3007D1PWR
266 ₽
TPA3007D1PWR
720 ₽
ЭИК
TPA3007D1PWR
от 776 ₽
TPA3007D1PWR
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTPA3007D1
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Analog Supply (V)8 Max
Closed/Open LoopOpen
Control InterfaceHardware
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Power Stage Supply(Max)18 В
Power Stage Supply(Min)8 В
Power to Bridge Tied Load(Max)6.5 W
Speaker Channels1 Max
Supported Bridge Tied Load(Min)8 Ohms
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA3007D1 (5)
  • Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
На английском языке: Datasheet Texas Instruments TPA3007D1PWR
