Datasheet Texas Instruments BQ24055DSSR — Даташит
СерияBQ24055
МодельBQ24055DSSR
Зарядное устройство для одноэлементной литий-ионной батареи, 1 А, с автоматическим определением переменного тока/USB и PG 12-WSON
bq2405x 1-A, Single-Cell Li-Ion and Li-Pol Battery Charger With Automatic Adaptor and USB Detection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 дек 2014
Микросхема Чип управления батареи, Battery Charge Management 800mA, Single-Input, Single Cell Li-Ion Battery Charger with Automatic AC/USB Detection and PG Battery...
BQ24055DSSR
38 ₽
BQ24055DSSR
41 ₽
BQ24055DSSR
69 ₽
T-electron
BQ24055DSSR
4 762 ₽
Pin12
Package TypeDSS
Industry STD TermWSON
JEDEC CodeR-PDSO-N
Package QTY3000
МаркировкаCGU
Width (мм)3
Length (мм)2
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
  • Evaluation Modules & Boards: BT-MSPAUDSOURCE
    Bluetooth and MSP430 Audio Source Reference Design Board
  • Evaluation Modules & Boards: BQ24055EVM
    BQ24055 Evaluation Module: 0.8-A, Single-Input, Single-Cell Li-Ion Battery Charger
  • Automatic AC/USB Detection in bq24050/2/5 Using D+/D- pins
    PDF, 134 Кб, Файл опубликован: 25 янв 2010
    Modern day electronic devices, such as cell phones and MP3 players, can usually be powered with either an adapter or USB source through a single input connector using a mini USB cable. For a simple charger, without separate power paths for the system and the battery, the system (including the device transceiver) is powered directly from the battery. If the battery is deeply discharged, it has to
  • Selecting the Best bq2404x/5x/9x Single Cell Battery Charger for your Applicatio
    PDF, 38 Кб, Файл опубликован: 29 ноя 2012
Серия: BQ24055 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24055DSSR
