Datasheet Texas Instruments UC1854L — Даташит
Серия | UC1854 |
Модель | UC1854L |
UCx854 High-Power Factor Preregulator datasheet
PDF, 949 Кб, Версия: A, Файл опубликован: 16 дек 2016
Купить UC1854L на РадиоЛоцман.Цены — от 3 731 до 11 798 ₽ 8 предложений от 8 поставщиков Микросхема: 1.5 A POWER FACTOR DUAL MARKED ( | |||
UC1854L/883BC Texas Instruments | 3 731 ₽ | ||
UC1854L/883BC Texas Instruments | 3 966 ₽ | ||
UC1854L/883BC Texas Instruments | 4 778 ₽ | ||
UC1854L Texas Instruments | по запросу |
Pin | 20 |
Package Type | L |
Рекомендуемая замена
Replacement | UC1854J |
Replacement Code | P |
Control Method | CCM |
Duty Cycle(Max)(%) | 95 |
Operating Temperature Range(C) | -55 to 125 |
Package Group | CDIP |
Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
Rating | Military |
Special Features | Average Current Mode Enable |
UVLO Thresholds On/Off(V) | 16/10 |
RoHS | Не совместим |
- U-134 UC3854 Controlled Power Factor Correction Circuit DesignPDF, 346 Кб, Файл опубликован: 5 сен 1999
The UC1854 provides active power factor correction for power systems that otherwise would draw non-sinusoidal current from sinusoidal power lines. This device implements all the control functions necessary to build a power supply capable of optimally using available power-line current while minimizing line-current distortion. This application note describes the concepts and design of a boost prere - DN-39E Optimizing Performance in UC3854 Power Factor Correction ApplicationsPDF, 277 Кб, Файл опубликован: 5 сен 1999
The performance of the UC3854 Power-Factor Correction IC in the 250W application example has been evaluated using a precision PFC/THD instrument. The result was a power factor of 0.999 and Total Harmonic Distortion (THD) of 3.81%, measured to the 50th line frequency harmonic at nominal line and full load. Users should get similar results at these conditions. as well as over most line and load rang - DN-41 Extend Current Transformer RangePDF, 37 Кб, Файл опубликован: 5 сен 1999
The problems with self reset of current transformers for unipolar pulse applications can be overcome with simple forced-reset techniques derived from magnetic amplifiers. Duty factors above 90% are achievable with these techniques. This design note describes a circuit configured for forced reset and a configuration that generates a negative voltage from the current transformer. - AC Requirements for Power Factor Correction CircuitsPDF, 29 Кб, Файл опубликован: 28 мар 2002
This technical brief identifies the recommended range of IAC for each of the devices within the UCC3854 family of PFC controllers. - Accurate PWM Duty Cycle ClampPDF, 58 Кб, Файл опубликован: 25 янв 2002
Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UC1854 (6)
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
