Datasheet Texas Instruments OPA347NA/3K — Даташит
Серия | OPA347 |
Модель | OPA347NA/3K |
Микромощный операционный усилитель Rail-To-Rail 5-SOT-23 от -55 до 125
microPower Rail-To-Rail Operational Amplifiers datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 20 июл 2007
![]() 43 предложений от 19 поставщиков Микросхема Операционный усилитель, Low Input Bias Current/FET InputMicropower Rail-To-Rail Operational Amplifier OP Amp Single GP R-R I/O 5.5V 5Pin SOT-23 T/R... | |||
OPA347NA/3K Texas Instruments | от 9.71 ₽ | ||
OPA347NA/3K Texas Instruments | от 25 ₽ | ||
OPA347NA/3K Mean Well | по запросу | ||
OPA347NA/3K Texas Instruments | по запросу |
Pin | 5 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | A47 |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
Additional Features | N/A |
Архитектура | CMOS |
CMRR(Min) | 70 дБ |
CMRR(Typ) | 80 дБ |
GBW(Typ) | 0.35 МГц |
Input Bias Current(Max) | 10 pA |
Iq per channel(Max) | 0.034 мА |
Iq per channel(Typ) | 0.02 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 3 uV/C |
Output Current(Typ) | 17 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.17 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 2.3 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 60 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 6 мВ |
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA347 (14)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > General-Purpose Op Amps
