Datasheet Texas Instruments TMP300BIDBVR — Даташит
Серия | TMP300 |
Модель | TMP300BIDBVR |
Программируемый резистором переключатель температуры до 18 В и датчик аналогового выхода 6-SOT-23 от -40 до 125
TMP300 1.8V, Resistor-Programmable Temperature Switch and Analog Out Temperature Sensor in SC70 datasheet
PDF, 956 Кб, Версия: D, Файл опубликован: 15 янв 2016
![]() 29 предложений от 13 поставщиков Температурные датчики для монтажа на плате 1.8V,Resistor-Prgrm Temp Switch | |||
TMP300BIDBVR Texas Instruments | от 28 ₽ | ||
TMP300BIDBVR Texas Instruments | 216 ₽ | ||
TMP300BIDBVR Texas Instruments | от 249 ₽ | ||
Pin | 6 |
Package Type | DBV |
Industry STD Term | SOT-23 |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | DUDC |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | 1.2 |
Pitch (мм) | .95 |
Max Height (мм) | 1.45 |
Mechanical Data | Скачать |
# Comparators | 1 |
Accuracy Over Temp Range(Max) | 2 C |
Interface | Analog Output,Switch |
Тип выхода | Open Drain |
Package Group | SOT-23 |
Package Size: mm2:W x L | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Sensor Gain | 10 mV/Deg C |
SetPoint Type | Resistor Programmable |
SetPoint Value | -40 to 125 deg C |
Special Features | Hysteresis (5В°C or 10В°C),Pin-Selectable Hysteresis,Temperature Sensor and Switch |
Supply Current(Typ) | 110 uA |
Supply Voltage(Max) | 18 В |
Supply Voltage(Min) | 1.8 В |
- Power Ref Design for TMS320C6472, 12-Vin Digital Pwr Cntrlrs, and LDOs (Rev. A)PDF, 559 Кб, Версия: A, Файл опубликован: 24 май 2010
This design was created to help those wanting to design a TMS320C6472 digital signal processor into a system using a nominal input of 12 V, having a highly flexible power design, and the ability to monitor temperature as well as dynamically monitoring and controlling voltage and current. - Pwr Ref Design f/'C6472 12-Vin Digital Pwr Controllers and LDOsPDF, 558 Кб, Файл опубликован: 28 апр 2010
This design was created to help designers wishing to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 12 V, having a highly flexible power design, the ability to monitor temperature, and dynamically monitor and control voltage and current.
Серия: TMP300 (10)
- Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
