Datasheet Texas Instruments TL750M05CKCE3 — Даташит
Серия | TL750M05 |
Модель | TL750M05CKCE3 |
LDO с одним выходом, 750 мА, фиксированный (5,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-220 от 0 до 125
Datasheet
![]() 13 предложений от 12 поставщиков Микросхемы управления электропитанием - Стабилизаторы напряжения - Линейные | |||
TL750M05CKCE3 Texas Instruments | 58 ₽ | ||
TL750M05CKCE3 Texas Instruments | от 131 ₽ | ||
TL750M05CKCE3 Texas Instruments | 162 ₽ |
Pin | 3 |
Package Type | KC |
Industry STD Term | TO-220 |
JEDEC Code | R-PSFM-T |
Маркировка | TL750M05C |
Width (мм) | 9.02 |
Length (мм) | 10.17 |
Thickness (мм) | 4.58 |
Pitch (мм) | 2.54 |
Max Height (мм) | 4.7 |
Mechanical Data | Скачать |
Accuracy(%) | 1 |
Additional Features | Overcurrent Protection Thermal Shutdown |
Approx. Price (US$) | 0.42 | 1ku |
Fixed Output Options(V) | 5 |
Iout(Max)(A) | 0.75 |
Iq(Typ)(mA) | 5 |
Noise(uVrms) | 500 |
Operating Temperature Range(C) | 0 to 125 |
Output Capacitor Type | Non-Ceramic |
Output Options | Fixed Output |
Package Group | TO-220 |
Package Size: mm2:W x L (PKG) | See datasheet (TO-220) |
Powered Load | FPGA Microcontroller Microprocessor |
Rating | Catalog |
Regulated Outputs(#) | 1 |
Vdo(Typ)(mV) | 600 |
Vin(Max)(V) | 26 |
Vin(Min)(V) | 6 |
Vout(Max)(V) | 5 |
Vout(Min)(V) | 5 |
RoHS | Не совместим |
- Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL750M05 (5)
- TL750M05CKC TL750M05CKCE3 TL750M05CKTER TL750M05CKTPR TL750M05CKTPRG3
