Datasheet Texas Instruments SN74LVC1G79DCKTG4 — Даташит
СерияSN74LVC1G79
МодельSN74LVC1G79DCKTG4
Одиночный триггер D-типа с запуском по положительному фронту 5-SC70 от -40 до 125
SN74LVC1G79 Single Positive-Edge-Triggered D-Type Flip-Flop datasheet
PDF, 1.2 Мб, Версия: U, Файл опубликован: 7 апр 2017
23 предложений от 15 поставщиков
Микросхема Бистабильный мультивибратор, Flip Flop D-Type Pos-Edge 1Element 5Pin SC-70 T/R
SN74LVC1G79DCKTG4
23 ₽
T-electron
SN74LVC1G79DCKTG4
26 ₽
SN74LVC1G79DCKTG4
33 ₽
ЭИК
SN74LVC1G79DCKTG4
от 82 ₽
Pin555
Package TypeDCKDCKDCK
Industry STD TermSOT-SC70SOT-SC70SOT-SC70
Package QTY250250250
CarrierSMALL T&RSMALL T&RSMALL T&R
МаркировкаCR5CRRCRF
Width (мм)1.251.251.25
Length (мм)222
Thickness (мм).9.9.9
Pitch (мм).65.65.65
Max Height (мм)1.11.11.1
3-State OutputNo
Bits1
F @ Nom Voltage(Max)150 Mhz
Gate TypeFLIP-FLOP
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)32/-32 мА
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
Schmitt TriggerNo
Special FeaturesIoff,down translation to Vcc,low power
Sub-FamilyD-Type Flip-Flop
Technology FamilyLVC
VCC(Max)5.5 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,3.3,5 В
tpd @ Nom Voltage(Max)12,8.5,6,5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G79DCKTG4
