Datasheet Texas Instruments TL1454ACNSR — Даташит
СерияTL1454A
МодельTL1454ACNSR
Двухканальная схема управления с широтно-импульсной модуляцией (ШИМ) 16-SO от -20 до 85
Dual-Channel Pulse-Width-Modulation (PWM) Control Circuit datasheet
PDF, 882 Кб, Версия: A, Файл опубликован: 25 сен 2002
Чип стабилизации напряжения, DC DC Cntrlr Dual-OUT PWM DC to DC Controller 3.6V to 20V Input 16Pin SOP T/R
T-electron
TL1454ACNSR
137 ₽
IC Home
TL1454ACNSR
202 ₽
TL1454ACNSR
LifeElectronics
TL1454ACNSR
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаTL1454A
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments TL1454ACNSR
