Datasheet Texas Instruments LM1875T/LB03 — Даташит
Серия | LM1875 |
Модель | LM1875T/LB03 |
Усилитель мощности звука 20 Вт 5-TO-220 0–70
LM1875 20W Audio Power Amplifier datasheet
PDF, 3.3 Мб, Версия: A, Файл опубликован: 13 май 2004
![]() 27 предложений от 15 поставщиков , Audio Amp Single Speaker 1Channel Mono 25W Class-AB 5Pin (5+tab) TO-220 | |||
LM1875T/LB03 Texas Instruments | 135 ₽ | ||
LM1875T/LB03 Texas Instruments | от 212 ₽ | ||
LM1875T/LB03 Texas Instruments | 409 ₽ | ||
LM1875T-LB03 Texas Instruments | по запросу |
Pin | 5 |
Package Type | NDH |
Industry STD Term | TO-220 |
JEDEC Code | R-MSFM-L |
Package QTY | 45 |
Carrier | TUBE |
Маркировка | LM1875T |
Width (мм) | 10.16 |
Length (мм) | 14.986 |
Thickness (мм) | 4.572 |
Pitch (мм) | 1.702 |
Max Height (мм) | 4.7 |
Mechanical Data | Скачать |
Analog Supply (V) | 60 Min |
Audio Input Type | Analog |
Closed/Open Loop | Open |
Control Interface | Hardware |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | TO-220 |
Package Size: mm2:W x L | See datasheet (TO-220) PKG |
Power Stage Supply(Max) | 60 В |
Power Stage Supply(Min) | 16 В |
Rating | Catalog |
Speaker Channels | 1 Max |
RoHS | See ti.com |
- Evaluation Modules & Boards: OPAMPEVM
Universal Operational Amplifier Evaluation Module
- Guidelines for Measuring Audio Power Amplifier PerformancePDF, 765 Кб, Файл опубликован: 30 окт 2001
This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply. - AN-1849 An Audio Amplifier Power Supply Design (Rev. B)PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
Серия: LM1875 (8)
- Semiconductors > Audio > Mid-Power Audio Amplifiers (10-50W) > Analog Input Amplifiers
