Datasheet Texas Instruments TMS320F28031PNT — Даташит
СерияTMS320F28031
МодельTMS320F28031PNT
Микроконтроллер Piccolo 80-LQFP от -40 до 105
TMS320F2803x Piccoloв„ў Microcontrollers datasheet
PDF, 1.6 Мб, Версия: K, Файл опубликован: 24 июн 2016
37 предложений от 16 поставщиков
727GS
TMS320F28031PNT
от 48 ₽
TMS320F28031PNT
от 125 ₽
IC Home
TMS320F28031PNT
802 ₽
ЭИК
TMS320F28031PNT
от 2 193 ₽
Pin8080
Package TypePNPN
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY119119
CarrierJEDEC TRAY (10+1)JEDEC TRAY (10+1)
МаркировкаTMS320F28031PNT
Width (мм)1212
Length (мм)1212
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC16,14,13 Ch
ADC Resolution12-bit
CAN1
CPUC28x
Comparators3
FPUNo
Flash64 KB
Тактовая частота60 МГц
I2C1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM14,12,8 Ch
Pin/Package56VQFN, 64TQFP, 80LQFP
QEP1
RAM16 KB
SPI2,1
Total Processing60 MIPS
UART1 SCI
  • Evaluation Modules & Boards: TMDSCNCD28035
    F28035 Piccolo controlCARD
  • Evaluation Modules & Boards: TMDSDCDCLEDKIT
    DC/DC LED Developer's Kit
  • Evaluation Modules & Boards: TMDSHVMPPTKIT
    High Voltage Isolated Solar MPPT Developers Kit
  • Evaluation Modules & Boards: TMDSCNCD28035ISO
    Piccolo TMS320F28035 Isolated controlCARD
  • Evaluation Modules & Boards: TMDSSOLARPEXPKIT
    Piccolo-based Solar Explorer Development Kit
  • Evaluation Modules & Boards: TMDSDOCK28035
    F28035 Piccolo Experimenter's Kit
  • Evaluation Modules & Boards: DRV8302-HC-C2-KIT
    Three Phase BLDC & PMSM Motor Kit with DRV8302 and Piccolo MCU
  • Evaluation Modules & Boards: DRV8301-HC-C2-KIT
    Three Phase BLDC & PMSM Motor Kit with DRV8301 and Piccolo MCU
  • Evaluation Modules & Boards: TMDSHVBLPFCKIT
    HV Bridgeless PFC Developer's Kit
  • Evaluation Modules & Boards: TMDSHVMTRPFCKIT
    High Voltage Motor Control and PFC Developer's Kit
  • Evaluation Modules & Boards: LEDSPIMCUEVM-879
    TPS92518 Dual Buck Evaluation Board with SPI Interface
  • Evaluation Modules & Boards: DRV8312-C2-KIT
    Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU
  • Evaluation Modules & Boards: TMDSILPFCKIT
    C2000 2 Phase Interleaved Power Factor Correction Kit with integrated power metering
  • Evaluation Modules & Boards: TMDSSOLARUINVKIT
    Solar Micro Inverter Development Kit
  • Evaluation Modules & Boards: TMDSRSLVR
    C2000 Resolver to Digital Conversion Kit
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Trapezoidal Control of BLDC Motors Using Hall Effect Sensors
    PDF, 1.7 Мб, Файл опубликован: 1 июл 2013
    This application report presents a solution for the control of brushless DC motors using theTMS320F2803x microcontrollers. TMS320F280x devices are part of the C2000в„ў family ofmicrocontrollers that enable the cost-effective design of intelligent controllers for three-phase motors byreducing the system components and increasing efficiency. Using these devices, it is possible to realizefar mo
  • Sensorless Field Oriented Control of Multiple Permanent Magnet Motors
    PDF, 796 Кб, Файл опубликован: 1 июл 2013
    This application report presents a solution to control multiple permanent magnet synchronous motors(PMSM, BLDC, and so forth ) simultaneously using the TMS320F2803x microcontrollers. Although themotors included in the “Multi Axis +PFC Kit” are brushless dc (BLDC), the same experimental procedurecan be applied to various permanent magnet motors. TMS320F2803x devices are part of the family of
  • Sensorless Field Oriented Control of 3-Phase Induction Motors
    PDF, 1.9 Мб, Файл опубликован: 29 окт 2013
    This application report presents a solution to control an AC induction motor using the TMS320F2803xmicrocontrollers. TMS320F2803x devices are part of the family of C2000в„ў microcontrollers which enablecost-effective design of intelligent controllers for three phase motors by reducing the system componentsand increase efficiency. With these devices it is possible to realize far more prec
  • Sensored Field Oriented Control of 3-Phase Permanent Magnet Synchronous Motors
    This application report presents a solution to control a permanent magnet synchronous motor (PMSM)using the TMS320F2803x microcontrollers. TMS320F2803x devices are part of the family of C2000microcontrollers, which enables the cost-effective design of intelligent controllers for three phase motorsby reducing system components and increasing efficiency. With these devices, it is possible to r
  • LED Lighting & DC/DC Conversion Control Integrated on One C2000 Microcontroller
    PDF, 3.5 Мб, Файл опубликован: 17 сен 2013
    This application report presents a solution to control an LED lighting system using TMS320F2803xmicrocontrollers. The Piccoloв„ў TMS320F2803x series of devices are part of the family of C2000microcontrollers which enable cost-effective design of LED lighting systems. With these devices it ispossible to control multiple strings of LEDs in an efficient and very accurate way. In addition, t
  • Digital Peak Current Mode Control With Slope Compensation Using the TMS320F2803x (Rev. A)
    PDF, 416 Кб, Версия: A, Файл опубликован: 17 апр 2012
    This application report describes a method of implementing the digital peak current mode control of a power supply using the Texas Instruments Piccoloв„ў MCUs. The theory of operation and all relevant equations are given, as well as a design example and complete compile ready project files. The implementation method described is similar to that taught in Digital Power Design Workshops delivere
  • Scalar (V/f) Control of 3-Phase Induction Motors
    PDF, 1.5 Мб, Файл опубликован: 1 июл 2013
    This application report presents a solution to control an AC induction motor using the TMS320F2803xmicrocontrollers. TMS320F2803x devices are part of the family of C2000в„ў microcontrollers that enablecost-effective design of intelligent controllers for 3-phase motors by reducing the system components andincrease efficiency. In this system, the scalar control (V/Hz) of induction motor experime
  • Sensored Field Oriented Control of 3-Phase Induction Motors
    PDF, 1.8 Мб, Файл опубликован: 1 июл 2013
    This application report presents a solution to control an AC induction motor using the TMS320F2803xmicrocontrollers. TMS320F2803x devices are part of the family of C2000 microcontrollers, which enablecost-effective design of intelligent controllers for three phase motors by reducing the system componentsand increase efficiency. With these devices, it is possible to realize far more precise d
  • Sensorless Field Oriented Control of 3-Phase Induction Motors Using CLA
    PDF, 1.8 Мб, Файл опубликован: 29 окт 2013
    This application report presents a solution to control an AC induction motor using the Control LawAccelerator (CLA) which is a small foot print coprocessor present on some of the microcontrollers from the C2000в„ў family of MCU. TMS320F2803x devices are part of the family of C2000microcontrollers which enable cost-effective design of intelligent controllers for three phase motors byreducing
  • Sensorless Field Oriented Ctrl of 3-Phase Perm. Magnet Synch. Motors-HVDMC Kit
    PDF, 1.9 Мб, Файл опубликован: 1 июл 2013
  • Sensorless Trapezoidal Control of BLDC Motors (Rev. A)
    PDF, 1.8 Мб, Версия: A, Файл опубликован: 14 сен 2015
  • Digital Control of Two Phase Interleaved PFC and Motor Drive Using MCU With CLA
    PDF, 242 Кб, Файл опубликован: 1 июл 2013
    Power factor correction (PFC) is used in power systems operating from single phase AC to correct for thenon linearity of the rectifier. Use of PFC in motor drives is increasing because of increased regulation fromthe power utility side. However, integration of PFC and field oriented control of motor on a single controllerremains challenging from a processor bandwidth point of view while keep
  • Sensorless Field Oriented Control:3-Phase Perm.Magnet Synch. Motors With CLA
    This application report presents a solution to control a permanent magnet synchronous motor (PMSM)using the control law accelerator (CLA), which is a small footprint coprocessor that is present on some ofthe microcontrollers from the C2000в„ў family of MCU. TMS320F2803x devices are part of the family ofC2000 microcontrollers, which enables the cost-effective design of intelligent controllers f
  • Software Implementation of PMBus over I2C for TMS320F2803x
    PDF, 95 Кб, Файл опубликован: 14 мар 2011
    Power Management Bus (PMBus) is a free and open standard communications protocol for power management devices. This application report provides a software implementation of the PMBus protocol over the inter-integrated circuit (I2C) hardware on TMS320F28035 Piccoloв„ў MCUs. The software implementation provides functions to control the underlying I2C as well as to handle PMBus transactions as either a
  • Piccolo MCU CAN Module Operation Using the On-Chip Zero-Pin Oscillator (Rev. A)
    PDF, 43 Кб, Версия: A, Файл опубликован: 19 авг 2011
    CAN protocol imposes rather stringent requirements on its timing source, which are generally met by the provision of an external quartz crystal/oscillator. The TMS320C2803x/TMS320F2806x series of microcontrollers have an on-chip zero-pin oscillator that needs no external components. This application report describes how to use the CAN module with this oscillator to operate at the maximum bit rate
  • Digitally Controlled HV Solar MPPT DC-DC Converter Using C2000 Piccolo MCU
    PDF, 3.3 Мб, Файл опубликован: 29 май 2012
    This application report presents the implementation details of a digitally controlled DC-DC converter that is used as a front-end converter for solar inverter (DC-AC) application. It implements an isolated DC-DC stage with maximum power point tracking (MPPT) algorithm in order to utilize the full capacity of a 500W solar panel. It maintains its input voltage at the reference set point generated by
  • PSFB Control Using C2000 Microcontrollers
    PDF, 2.2 Мб, Файл опубликован: 22 май 2013
    The phase shifted full bridge (PSFB) converter is used for DC-DC conversion in various applications, forexample, in telecom systems to convert a high voltage bus to an intermediate distribution voltage, typicallycloser to 48 V. PSFB stage provides voltage translation as well as isolation from the line voltage, sincethis topology includes a transformer.This application report presents
  • TMS320F280x to TMS320F2802x/TMS320F2803x Migration (Rev. C)
    PDF, 119 Кб, Версия: C, Файл опубликован: 11 авг 2015
    This application report describes differences between the Texas Instruments TMS320x280x/2801x/2804x and TMS320F2802x/2803x microcontrollers to assist in application migration. While the main focus of this document is migration from 280x/2801x/2804x to 2802x/2803x, you will also find this document useful if you are considering migrating in the reverse direction. Functions that are identical in both
  • The TMS320F28004x MCU: A Comparison to the TMS320F2806x and TMS320F2803x MCUs
    PDF, 269 Кб, Файл опубликован: 22 июн 2017
    The Texas Instruments Piccoloв„ў TMS320F28004x microcontroller (MCU) device series offers an optimal balance between performance and cost for many real-time control systems. This document discusses the technical details of the TMS320F28004x architecture and highlights the new improvements to various key peripherals, such as an enhanced Type-2 CLA capable of running a background task, and the i
  • Using the CAN Piccolo Bootloader at High Temperature
    PDF, 33 Кб, Файл опубликован: 29 июн 2015
    The Controller Area Network (CAN) protocol requires strict tolerances from reference bit clocks, which are generally met using quartz crystal oscillators or ceramic resonators. The TMS320F2803x, TMS320F2805x, and TMS320F2806x microcontrollers use an on-chip zero-pin oscillator with no external components as a reference clock for the CAN bootloader. This oscillator's tolerance is sufficient at room
  • Piccolo TMS320F2802x/2803x Migration to TMS320F2806x
    PDF, 105 Кб, Файл опубликован: 1 мар 2011
    This application report describes differences between Texas Instruments' TMS320F2802x/2803x and TMS320F2806x microcontrollers to assist in application migration. While the main focus of this document is migration from 2802x/2803x to 2806x, this document is also useful if you are considering migrating in the reverse direction. Functions that are identical in both devices are not necessarily include
  • InstaSPIN(tm) BLDC Lab
    PDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
    For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit
  • Programming Examples for the TMS320x28xx eCAN (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
    The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments TMS320F28031PNT
