Datasheet Texas Instruments SN74LVC126APWG4 — Даташит
СерияSN74LVC126A
МодельSN74LVC126APWG4
Четверной буферный вентиль шины с выходами с 3 состояниями 14-TSSOP от -40 до 125
SN74LVC126A Quadruple Bus Buffer Gate With 3-State Outputs datasheet
PDF, 1.1 Мб, Версия: S, Файл опубликован: 6 фев 2017
19 предложений от 13 поставщиков
Микросхема Логический контроллер, Buffer/Line Driver 4CH Non-Inverting 3-ST CMOS 14Pin TSSOP Tube
T-electron
SN74LVC126APWG4
9.58 ₽
SN74LVC126APWG4
от 11 ₽
SN74LVC126APWG4
156 ₽
SN74LVC126APWG4
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаLC126A
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Bits4
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.04 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)9.3,6.7,5,4.5 нс
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC126APWG4
