Datasheet Texas Instruments OPA336PA — Даташит
Серия | OPA336 |
Модель | OPA336PA |
КМОП-операционные усилители MicroPower с однополярным питанием MicroAmplifier(TM) Series 8-PDIP
OPA336, 2336, 4336: Single-Supply, microPower CMOS Op Amp microAmplifier Series datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 11 янв 2005
![]() 13 предложений от 13 поставщиков Микросхема Операционный усилитель, Op Amp Single GP R-R O/P 5.5V 8Pin PDIP Tube | |||
OPA336PA Texas Instruments | 31 ₽ | ||
OPA336PA Texas Instruments | 40 ₽ | ||
OPA336PA Texas Instruments | по запросу | ||
OPA336PA | по запросу |
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | OPA336UA |
Replacement Code | F |
Additional Features | N/A |
Approx. Price (US$) | 0.40 | 1ku |
Архитектура | CMOS |
CMRR(Min)(dB) | 76 |
CMRR(Typ)(dB) | 86 |
GBW(Typ)(MHz) | 0.1 |
Input Bias Current(Max)(pA) | 10 |
Iq per channel(Max)(mA) | 0.032 |
Iq per channel(Typ)(mA) | 0.02 |
Number of Channels(#) | 1 |
Offset Drift(Typ)(uV/C) | 1.5 |
Operating Temperature Range(C) | -40 to 85 |
Output Current(Typ)(mA) | 5 |
Package Group | SOIC SOT-23 |
Package Size: mm2:W x L (PKG) | See datasheet (PDIP) |
Rail-to-Rail | In to V- Out |
Rating | Catalog |
Slew Rate(Typ)(V/us) | 0.03 |
Total Supply Voltage(Max)(+5V=5, +/-5V=10) | 5.5 |
Total Supply Voltage(Min)(+5V=5, +/-5V=10) | 2.3 |
Vn at 1kHz(Typ)(nV/rtHz) | 40 |
Vos (Offset Voltage @ 25C)(Max)(mV) | 0.125 |
RoHS | Не совместим |
- Solder Pad Recommendations for Surface-Mount Devices (Rev. A)PDF, 91 Кб, Версия: A, Файл опубликован: 28 апр 2003
Cost and performance requirements continue to push the packaging of electronic systems into smaller and smaller spaces. The advent of surface-mount devices has brought pin spacings that differ from one package series to the next. This application report addresses criteria for well-designed solder joints and provides the design engineer with useful tabular data of some of the more popular packages - Precision Absolute Value CircuitsPDF, 100 Кб, Файл опубликован: 2 окт 2000
You can build a precision absolute value circuit using two op amps and two precision resistors. If you use an op amp and an IC difference amplifier no user supplied precision resistors or resistor adjustments are required. Circuits shown are suitable for precision split supply operation and for single-supply operation. When used with a rail-to-rail op amp the single supply circuit can approach a - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA336 (23)
