Datasheet Texas Instruments 5962-9665801QDA — Даташит
Серия | SN54LS14 |
Модель | 5962-9665801QDA |
Инверторы с шестигранным триггером Шмитта 14-CFP от -55 до 125
SNx414 and SNx4LS14 Hex Schmitt-Trigger Inverters datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 30 ноя 2016
![]() 7 предложений от 6 поставщиков Микросхема Логический контроллер, Inverter Schmitt Trigger 6Element Bipolar 14Pin CFPAK Tube | |||
5962-9665801QDA Texas Instruments | от 851 ₽ | ||
5962-9665801QDA Texas Instruments | 1 475 ₽ | ||
5962-9665801QDA Texas Instruments | по запросу | ||
Pin | 14 | 14 | 14 |
Package Type | W | W | W |
Industry STD Term | CFP | CFP | CFP |
JEDEC Code | R-GDFP-F | R-GDFP-F | R-GDFP-F |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | SNJ54LS14W | 5962-9665801QD | A |
Width (мм) | 5.97 | 5.97 | 5.97 |
Length (мм) | 9.21 | 9.21 | 9.21 |
Thickness (мм) | 1.59 | 1.59 | 1.59 |
Pitch (мм) | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 |
Bits | 6 |
Тип входа | TTL |
Тип выхода | TTL |
Package Group | CFP |
Package Size: mm2:W x L | See datasheet (CFP) PKG |
Rating | Military |
Schmitt Trigger | Yes |
Technology Family | LS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
RoHS | See ti.com |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - TI IBIS File Creation Validation and Distribution ProcessesPDF, 380 Кб, Файл опубликован: 29 авг 2002
The Input/Output Buffer Information Specification (IBIS) also known as ANSI/EIA-656 has become widely accepted among electronic design automation (EDA) vendors semiconductor vendors and system designers as the format for digital electrical interface data. Because IBIS models do not reveal proprietary internal processes or architectural information semiconductor vendors? support for IBIS con - Live InsertionPDF, 150 Кб, Файл опубликован: 1 окт 1996
Many applications require the ability to exchange modules in electronic systems without removing the supply voltage from the module (live insertion). For example an electronic telephone exchange must always remain operational even during module maintenance and repair. To avoid damaging components additional circuitry modifications are necessary. This document describes in detail the phenomena tha - Understanding and Interpreting Standard-Logic Data Sheets (Rev. C)PDF, 614 Кб, Версия: C, Файл опубликован: 2 дек 2015
- Semiconductor Packing Material Electrostatic Discharge (ESD) ProtectionPDF, 337 Кб, Файл опубликован: 8 июл 2004
Forty-eight-pin TSSOP components that were packaged using Texas Instruments (TI) standard packing methodology were subjected to electrical discharges between 0.5 and 20 kV as generated by an IEC ESD simulator to determine the level of ISD protection provided by the packing materials. The testing included trays tape and reel and magazines. Additional units were subjected to the same discharge - Understanding Schmitt TriggersPDF, 80 Кб, Файл опубликован: 21 сен 2011
- Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
The Texas Instruments (TI) SN54/74LS123 dual retriggerable monostable multivibrator is a one-shot device capable of verylong output pulses and up to 100% duty cycle. The ?LS123 also features dc triggering from gated low-level active A andhigh-level active B inputs and provides a clear input that terminates the output pulse of any predetermined time independentof timing components R ext and - Introduction to LogicPDF, 93 Кб, Файл опубликован: 30 апр 2015
Серия: SN54LS14 (9)
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
59629665801QDA, 5962 9665801QDA
