Datasheet Texas Instruments DAC2904Y/250 — Даташит
Серия | DAC2904 |
Модель | DAC2904Y/250 |
Двухканальный 14-битный цифро-аналоговый преобразователь (ЦАП) с быстродействием 125 MSPS 48-TQFP от -40 до 85
Dual, 14-Bit, 125 MSPS Digital-to-Analog Converter datasheet
PDF, 885 Кб, Версия: C, Файл опубликован: 14 окт 2004
![]() 42 предложений от 19 поставщиков Микросхема Преобразователь DA, Dual-Channel, 14Bit, 125MSPS Digital-to-Analog Converter (DAC) 48-TQFP -40℃ to 85℃ | |||
DAC2904Y/250G4 Texas Instruments | от 278 ₽ | ||
DAC2904Y/250 Texas Instruments | от 779 ₽ | ||
DAC2904Y/250 Texas Instruments | от 6 285 ₽ | ||
DAC2904Y/250 Texas Instruments | по запросу |
Pin | 48 |
Package Type | PFB |
Industry STD Term | TQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | DAC2904Y |
Width (мм) | 7 |
Length (мм) | 7 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Архитектура | Current Source |
DAC Channels | 2 |
Interface | Parallel CMOS |
Interpolation | 1x |
Package Group | TQFP |
Package Size: mm2:W x L | 48TQFP: 81 mm2: 9 x 9(TQFP) PKG |
Power Consumption(Typ) | 310 mW |
Rating | Catalog |
Разрешение | 14 Bits |
SFDR | 80 дБ |
Sample / Update Rate | 125 MSPS |
- Evaluation Modules & Boards: TSW2200EVM
TSW2200 Low-Cost Portable Power Supply Evaluation Module
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
Серия: DAC2904 (5)
- DAC2904IPFB DAC2904Y/1K DAC2904Y/1KG4 DAC2904Y/250 DAC2904Y/250G4
- Semiconductors > Data Converters > Digital-to-Analog Converters (DACs) > High Speed DACs (>10MSPS)
